Custom Masking Solutions
Control of Powder Film Thickness
Powder coating consultant Rodger Talbert offers insights for film build control when powder coating.
powder coating, powder coating industry, finishing
Rodger Talbert has more than 30 years experience in the powder coating industry.
Q: We are powder coating metal furniture and we have trouble getting uniform film thickness on all areas of the parts. We have a wider variety of shapes and sizes from very small fittings to 12' long benches. A lot of the products are fabricated with tubing but we also have some plate and flat stock construction. Our application is all manual with one sprayer on each side of the part. The line speed is between 4 and 6 FPM depending on the metal gauge and complexity of the part being coated. Our minimum film thickness is 3 mils to get the performance we need but we actually get anywhere from 1.5 to 5 mils on a regular basis. We need suggestions on how to adjust our spray guns to apply more uniform coverage.
A: Film build control starts with earth ground. If you have a lot of inconsistency in film thickness I would first make sure that your hooks are clean and you maintain good ground at all times. From a safety perspective, the industry recommends resistance lower than 1 megaohm from the part to the ground rail or other ground source. Personally, I would strive for zero resistance for efficiency. Measurement of ground is often done with a megger due to the high voltage output. I use a high-quality multi-meter because it is more sensitive to a minor powder build on the area being measured and if it says zero I know I have the best possible ground.
Rack design is also important to achieving good application uniformity. Parts should be profiled as much as possible to avoid having to throw powder around one surface to get to another or reach around some area to get to an inside space. Keep the profile of the parts as accessible as possible so that all areas can be reached with a limited amount of angles or stretching. Avoid inconsistent racking and keep the racks in good repair. Always fill the rack up if possible and fix bad contacts. Dense racking (more metal, less empty space) is good up to a point. It improves efficiency and consistency. Just be careful to control the amount of the metal so that your sprayers can access all surfaces easily and keep up with the volume.
As for gun set-up, there are a few guidelines that help:
  • Make sure the powder is properly fluidized; too much or too little fluidizing air will cause spitting and break up the spray pattern. Keep the hopper as level as possible during the production day.
  • Adjust the voltage and microamps to a comfortable number; I start with full voltage and current at around 40 microamps. On flatter surfaces, the current may go a little higher. On complex surfaces with inside corners, the current can be lower.
  • Adjust the flow rate to a moderate output and make sure that the pattern is smooth and consistent. It is critical that the powder cloud have steady, lower velocity and the whole pattern is even, no spurts or heavy tails of powder in the pattern. I start a gun out at around 30 pounds per hour (4 grams per second). On a typical volume-based controller, that would be around a total air volume of 4.0 Nm3 (Normal Cubic Meters) with a powder percentage setting of 40%.
  • The sprayers should research and develop a consistent pattern and do it the same way at all times. Steady, slow strokes starting in the Faraday cage areas and working out to the easier surfaces from the inside corners.
  • Make sure the coaters are not rushed and have enough time to coat the parts. If they have to work too much they will turn up the flow rate and get more random in the spray pattern.
Practice and be consistent with moderate flow rates. Use slow and steady strokes. Start in the Faraday cage areas (recesses) and work to the flatter surfaces. If your sprayers follow these rules they should get the uniformity that you need.
Steelman Industries Inc.
Powder Coating Institute
Custom Making Solutions
Parts Cleaning Conference
CFS
Ask The Expert
Making sure that all of the pre-processing fluids are removed prior to plating is not as simple as it seems. Rich Held of Haviland Products outlines three tests that can help verify that your parts are clean.
Ask The Expert
Anodizing
Electroplating
basics
Understanding AAMA Specifications
Powder coating consultant Rodger Talbert explains AAMA specifications and considerations coaters should make before taking on work required to meet those standards.
Ask The Expert
TGIC Powder Coatings vs. Non-TGIC Powder Coatings
As raw materials become increasingly scarce, powder coating consultant Rodger Talbert offers insights into using non-TGIC products.
