Water Wash Filtration
Snapshots of the finishing industry.
metal finishing, aerospace finishing, conversion coating
Photo Credit: Products Finishing
A technician at Aircraft X-Ray Laboratories (Huntington Park, Calif.) applies a chromate conversion coating to aerospace parts in a water wash paint booth. The water filtration system uses circulating water to trap paint overspray, depositing it into a collection tank for periodic removal.
With a long history serving the aerospace industry, Aircraft X-Ray Laboratories has approvals from such companies as Bell Helicopter, Boeing, Lockheed Martin and Northrop Grumman.
  • Hexavalent-Chromium-Free Aluminum Sacrificial Paint Validation
    Hexavalent chromium is a known carcinogen, repro-toxin and mutagen.  Its elimination is of high importance to the aerospace industry, which has struggled to find high performing alternatives.  Legacy aluminum sacrificial paints have traditionally utilized hexavalent chromium to prevent corrosion and coatings which are equal to or better than have been difficult.  This second of two papers discusses the hexavalent-chromium-free process from the user point-of-view in terms of the process validation work by Rolls Royce Corporation.
  • Corrosion Protection Via Selective Plating
    Carbon and high strength steels are some of the most widely used metals today, and the corrosion of this type of material is a serious problem for a variety of industries. However, corrosion can largely be controlled with developments in various protective solutions. Sarah Medeiros, Corrosion Engineer at SIFCO ASC, discusses developments in R&D to help slow down the corrosion process.
  • A Smooth Transition from One Anodizing Process to Another
    Knowing when to switch from chromic acid anodizing to thin film sulfuric acid anodizing is important. Learn about why the change should be considered and the challenges in doing so.
Carlisle Fluid Technologies Finishing Solutions
Precision gear pumps
FABTECH 2024
Fischer Technology, Inc.
Gardner Intelligence
CFS
