Attention to Measurement
English vs. Metric — which should you use? Ron Kinne of Haviland Enterprises Inc. explains why you need a firm understanding of both for measuring various aspects of plating processes.
Ron Kinne, Haviland Enterprises Inc.
Q: Why does it seem like everyone is constantly switching between standard and metric measurements? Can’t we just pick one and use it everywhere?
A: In electroplating processes, the first choice between Metric and English units often depends on the location of the plating company and the industry standards followed in that region. For example, in North America, companies generally use the English system, while in Europe and many other parts of the world, the Metric system is more common. Some industries, such as aerospace and automotive, have established specific standards that require the use of one system or the other.
After that, when it comes to measuring plating parameters more specifically, certain units are more commonly used for specific parameters. Current density, for example, is typically measured in amperes per square foot (ASF) in the English system and amperes per square decimeter (ASD) in the Metric system. Other parameters, such as plating thickness, are commonly expressed in units of mils (thousandths of an inch) in the English system or micrometers (millionths of a meter) in the Metric system.
Bath temperature is another parameter that is commonly measured in electroplating processes, and the units used for this parameter vary by system. In the English system, temperature is typically measured in degrees Fahrenheit (°F), while in the Metric system, it is measured in degrees Celsius (°C). Conversion between these units is straightforward: to convert Fahrenheit to Celsius, subtract 32 from the Fahrenheit temperature and multiply the result by 5/9. To convert Celsius to Fahrenheit, multiply the Celsius temperature by 9/5 and add 32.
When it comes to expressing the concentration of specific substances in plating baths, the units used can vary. For example, the concentration of sulfuric acid in a plating bath may be expressed in grams per liter (g/L) or ounces per gallon (oz/gal), depending on the preference of the plating company or the industry standard in the region. To convert from oz/gal to g/l you multiply by 7.5, or if going from g/l to oz/gal, you divide by 7.5. Other substances commonly used in plating baths, such as nickel, copper, and gold, may be expressed in units of parts per million (ppm), grams per liter (g/L), or ounces per gallon (oz/gal), depending on the situation.
Adding substances to a plating bath requires careful calculation of the amount of material needed, based on the desired concentration, the volume of the bath, and the concentration of the material being added. In many cases, conversion factors must be used to convert between Metric and English units. For example, if a technician needs to add 10 ppm of a substance to a 500-gallon plating bath, they must first calculate the amount of substance needed in grams per liter or ounces per gallon, and then convert that amount to the appropriate unit. Conversion tables or calculators are often used to simplify this process.
A common issue that arises in plating facilities is how additions are made. Typically, recommendations for additions are made by people in an analytical lab either on sight or based on samples sent out to outside labs. The recommended additions may be in English or Metric, but once it gets communicated to the solution maintenance personnel on the line, it can morph into almost anything. For example, a lab could call for a 10-pound or 5-kilogram addition. This can change once it reaches the production floor into 2-3 scoops, ½ a bucket, or a partial bag. A 3-ounce add can change into 85 milliliters, a pint, ½ a coffee cup, or to just enough to cover the bottom of a 5-gallon bucket. It cannot be stressed enough that when making adds to your plating process, the additions be made accurately. Scales and graduated measuring containers of the appropriate sizes are essential. Having dedicated pumps, pails, and scoops for each chemical of the right size for each chemical in a plating facility is a very small cost compared to the potential problems that incorrect or contaminated adds can cause.
In conclusion, the units used in electroplating processes vary depending on the location of the plating company, the industry standards followed in that region, or simply what is easiest for the “thing” being measured. It is important that technicians are familiar with both Metric and English units to properly measure and adjust plating parameters and then must carefully calculate the amount of material needed when adding substances to plating baths. This requires both knowledge of the relevant conversion factors and the ability to use conversion tables or calculators when necessary.
About the Author
Ron Kinne
Photo Credit: Haviland Enterprises Inc.
Ron Kinne
Ron Kinne is a technical sales manager for Haviland Enterprises Inc. Visit havilandusa.com.
KCH Engineered Systems
EV Innovations
Trivalent Passivates
Luster-On Products
Filtration
FABTECH 2024
PF Podcast
Powder Coating
Salt spray can be useful to help compare different pretreatment methods and coatings but it does not tell us much about the corrosion resistance of a part over time in the field. Powder coating expert Rodger Talbert offers insights into how to get a better idea of how to improve a part’s corrosion resistance in the real world.
nasf
SUR/FIN 2023: Capsules from the Technical Sessions I: Emerging Technologies
SUR/FIN 2023 in Cleveland this past June was a resounding success.  Due to the efforts of the Technical Activities Committee, ably led by Bill Nebiolo this year, an outstanding program of technical presentations was offered.  What follows are summaries of selected presentations from the Emerging Technologies sessions.  Additional coverage will be provided in this space in the coming months.  The full report can be accessed and printed at short.pfonline.com/NASF23Aug1.
Updated Aluminum Finishes Documents Suite
AAMA 2063, 2064 and 2065 have been updated to help users make informed decisions about the types of aluminum finishes they need for their projects.
nasf
Smart Modeling and Simulation of Electroplating Systems for Real-Time Monitoring of Chemical, Water and Energy Consumption (NASF Summer Research Grant)
An AESF Foundation summer research grant provided an excellent opportunity for a PhD student to learn how to use chemical engineering fundamentals to scientifically characterize an electroplating process through integrated dynamic modeling and simulation, and how to develop digital twin (DT)-based virtual plant that can be of any process configuration.  This is a critical step for the investigation of new technology development for smart and sustainable manufacturing in the surface finishing industry.
Electroplating
Electroplating for Medical Devices
Brittany McKinney of Pavco Inc. discusses the benefits of electroplating for medical devices.
Electroplating
