Choosing Between a Conveyor vs. Batch Processing
Although many companies are converting to conveyor or continuous processing, Bob Hauck from Spray Systems says there are advantages and disadvantages to each type of processing.
Bob Hauck, Vice President, Spray Systems
Q: We are looking to add a new paint line to our manufacturing operation and wonder what are the advantages and disadvantages of a conveyor versus batch processing system.
A: Both conveyor and batch processing have distinct advantages and disadvantages, depending on the processes used in the assembly line. Batch processing is a cost-effective, well-established process that can sometimes be the only option for certain products. However, it doesn’t work well with a large-volume production of parts; can be time intensive; and is more likely to be less adaptable to error than other methods.
Conveyor processing is much faster and more efficient. It is also easier to scale up to meet customer demands and troubleshoot, but can have issues or special requirements with items that involve curing steps or a more complicated process. We'll define each process and how each can positively and negatively affect the overall production flow.
Batch Processing
Commonly used in chemical applications (including finishing), batch processing moves groups of parts from process to process. For example, if there is a chemical dip and then a curing process, 10 parts could be dipped at a time and then transferred to cure together. If graphed, batch processing appears as a stepwise function. There is a large bump in progress through the assembly flow because multiple parts are being treated at once. Then the progress levels out as parts wait to be moved to the next part of the production process.
Advantages: Batch processing techniques are well established and may sometimes be the only option for certain material processes. However, batch processing doesn’t work well with large volumes of parts, as it requires parts to be manually transitioned to the next stage of the finishing process. The biggest advantages of batch processing are the cost savings, work versatility and using even less floor space than conveyor processing! It’s the ideal solution for companies whose coating process outpaces the manufacturing process. This is the "saving space" option.
Disadvantages: Although multiple parts are processed at once, the wait time associated with batch processing can be a disadvantage. The downside of the stepwise motion is the large amount of time where no progress is made on a particular part. Inefficiencies arise as parts wait for prior parts to complete the next process. It can also be more difficult to recognize and react to issues in batch processing flow. If an issue is identified, it has likely affected a large number of parts in the batch proceeding through the process. This leads to more waste when issues are identified. Many of the parts in the batch may have to be discarded or reworked. Due to these disadvantages, many companies are working to convert their factories to continuous or conveyor processing.
Conveyor Processing
In conveyor processing, each part moves through the manufacturing process at the same rate. If graphed, conveyor processing would be a straight line moving from start to finish. There is no wait time or downtime because progress is happening constantly. Conveyors are often used to shuttle parts from process to process, as in a paint finishing system.
Advantages: Conveyor processing can often produce finished products at a faster rate than batch processing. There is no wait time while the previous part is being processed. The products move constantly toward completion. Unlike batch processing, conveyor processes can be adjusted to meet customer demands. A conveyor line can often be slowed down or sped up to meet changing demands. In contrast, a batch process designed for batches of 100 is not going to easily be able to accommodate batches of 50 or 200. It is often easier to spot and correct product finishing deficiencies in conveyor processing. If a single item is deficient, the line can be stopped and corrected before any other part reaches that part of the finishing process. The ability to halt the line reduces waste. A whole batch will not be wasted if there is an issue with a single process. Conveyor processing is well suited for manufacturers with a large volume of parts, as they won’t be required to manually move the parts into the next phase of the finishing process. However, it’s important to note that the continuous flow of a conveyor system isn’t suited for lines containing parts of varying size and shape.
Disadvantages: There are some processes that simply cannot be continuous. The wait time is built into the process itself. Waiting for items to cure or undergo chemical reactions is not well-suited to conveyor processing. Even though there are many advantages to conveyor processing, not all production lines can be continuous. It depends on the processes in the line and the product.
Although many companies are converting to conveyor or continuous processing, there are advantages and disadvantages to each type of processing. Batch processing is well established. Sometimes a batch process is the only way to complete a certain task, such as finishing larger parts. Waiting time is built into some processes. However, for processes that can be made continuous, there are advantages to adding a conveyor. Each part makes constant progress toward completion. It's also easier to identify when a part is deficient and make corrections before the next part is compromised. Despite the advantages of conveyor processing, each company has unique requirements that may be more suited to batch processing.
Bob Hauck is vice president at Spray Systems.
Precision gear pumps
Carlisle Fluid Technologies Finishing Solutions
Fischer Technology, Inc.
FABTECH 2024
Bulk Chemicals, Inc.
Filtration
SURFIN 2024
PF Podcast
automotive
basics
Curing Oven Basics
construction
Julie Holmquist of Cortec Corporation discusses passivating corrosion on rebar and other reinforcing metals.
Ask The Expert
regulation
automotive
Powder Coating
