Choosing the Right Powder Booth Technology
Is your powder coating operation experiencing an increasing number of color change requirements? Nicolas Gervaise of Carlisle Fluid Technologies discusses fast color change single booth configurations for powder coating.
#ask the expert #basics
Diagram of moder powder coating booth
Image Credit: Image courtesy of Carlisle Fluid Technologies
Q: We currently have two dedicated cartridge reclaim booths for high-volume colors and a third booth where we spray to waste all other colors. The system has suited us well for many years; however, we have seen a shift in demand and are now spraying more “other” colors. Our marketing team tells us the trend will continue. What are the options for improving our process? We do not want to continue spraying to waste as the cost is becoming considerable.
A: Many manufacturers have faced the same challenge you have described. Your original systems were once very efficient regarding powder utilization and color change time — two key drivers. As trends have changed regarding the demand for custom colors or the desire to manufacture to order/just in time, the need for more flexibility in the powder coating process has developed. To address this, fast color change single booth configurations are available. Note that “fast” is a relative term. A color change can typically be accomplished in 8–10 minutes for a single powder booth configuration. Now, this may be longer than your current process with dedicated booths; however, there are many benefits to the most recently designed systems.
Featured Content
The primary benefit is the ability to change colors efficiently; the system is designed specifically for this purpose. The booth is a non-metallic design with an air space in the walls; while in use, the walls will repel the powder allowing it to flow into the recovery system. The booth is connected to a cyclone separator through seamless ductwork, minimizing areas where the powder can accumulate. The cyclone separates the fine particles from the larger particles, which fall to the bottom of the cone. Airflow through the system is created by the after filter, which collects the fine particles that rise up in the cyclone. Air from the after filter is exhausted back into the powder coating area.
The powder center offers a central location for the operator to control the system and manage powder delivery and color changes. A powder box is placed on the vibrator table, and a transfer pump is lowered into the box. The transfer pump fills the fluidized hopper, equipped with an ultrasonic sieve that removes any contaminants in the powder. The fluidized hopper feeds individual venturi pumps for each manual or automatic applicator in the system. Additionally, the powder collected in the cyclone is fed back into the hopper and sieved. The reclaim powder is continually blended in the hopper with virgin powder, providing a better overall finish than your older system, where reclaim had to be collected and manually brought back into the process. The design of the system allows for up to 97% reclaim efficiency.
When it is time to change colors, the operator empties the powder from the hopper back into the box and then enters color change mode. The booth exit door closes, and the damper in the bottom of the booth that regulates airflow opens fully, allowing for maximum airflow through the booth and the powder center. The operator then uses an air lance to blow down the booth and equipment before loading the next color into the system.
Modern powder booths are designed to accommodate changing market needs for fast color change, high reclaim efficiency, and ease of use for the operator.
About the Author
Nicolas Gervaise headshot
Photo Credit: Carlisle Fluid Technologies
Nicolas Gervaise
Nicolas Gervaise is global product manager – powder for Carlisle Fluid Technologies. Visit carlisleft.com.
RELATED CONTENT
