Luster-On to Showcase Plating Barrel Line with Mesh Construction
Luster-On Products to showcase Sterling plating barrel line with unique mesh construction at SUR/FIN 2021
#surfin
Luster-On Products will showcase its Sterling plating barrel line with mesh construction along with a sampling of baskets, danglers and motor cartridge options.  The Sterling barrel specially-designed mesh provides excellent solution and electrical transfer to provide a faster, more efficient plating process of even the tiniest components.
Also on display will be the Aluminescent product line, a QPL approved trivalent chemistry for aluminum passivation fulfilling the requirements of Mil-DTL-5541F, Type II.  The Aluminescent is available in the only approved powdered product formulation, a liquid concentrate and a thixotropic version used for touch and repair work.
Luster-On Products Inc. | 413-739-2541 | luster-on.com
RELATED CONTENT
  • Direct Copper Metallization of Aluminum: Elimination of Zincate
    This article discusses the development of a new copper plating bath that can deposit high ductility copper metal directly on a wide range of aluminum alloy substrates.  The process is particularly important for general metal finishing companies looking to plate aluminum parts for aerospace industry.
  • Black Chromium Finishing: Beauty and the Beast
    Over the past 10 years, there has been commercial development of black chromium deposits from a trivalent chromium electrolyte.  This paper will review the deposit characteristics and operational consideration of these similar, but different chromium plating deposits.
  • Identifying New Alternatives for Chromium Plating
    A comprehensive review of chromium plating alternatives and a new look at a long-forgotten but potentially important process - iron plating
