Precision cleaning solvents
The Right Coating Opens Global Doors
Indiana manufacturer helps fight biodiesel’s effect on paint.
Biodiesel is known as an attractive alternative to traditional petroleum diesel fuel. It’s clean burning, renewable and gentler on our fragile planet. But when it comes to biodiesel’s effect on paint, it’s anything but nice.
This was the challenge Total Control Systems faced when the Fort Wayne, Indiana, company wanted to expand its production to include products made to handle the ever-increasing demand for biodiesel-compatible meters.
TCS is a leading ISO-9001 certified manufacturer of piston and rotary positive displacement flow meters that are designed to provide superior performance in custody-transfer measurement of refined fuels, LPG, fertilizers, chemicals, alcohols and solvents.
TCS manufactures flow meters mainly for the petroleum industry. Transport trucks, aircraft refuelers, home heating oil equipment and boats often include TCS meters.
TCS manufactures flow meters primarily for the petroleum industry.
The agriculture industry kept the company’s focus until about 2000, when leaders there decided to branch out into the meter business and serve a wider range of industries. Around 2005, the company started making products available to more customers and industries.
“At that time, painting became a big issue for us,” says David Musselman, the company’s CFO and COO. “We were branching out with customers who used biodiesel, which tends to remove paint.”
Musselman and his team began to experiment with many promising industrial coatings—including automotive paint—with the No. 1 criterion being its ability to stand up to biodiesel, and the second concern being the coating’s ability to stand up to ethanol.
Another major concern from an operations standpoint was VOCs. For environmental and employee safety reasons, Musselman wanted a paint with a low VOC rating.
Hunting Down a Coating
The environments in which TCS’s customers use meters are harsh, to say the least. First, the meters have to withstand the wear and tear of delivery, often in open-air trucks, across the United States and beyond. TCS has customers in Australia, Singapore and the Middle East, with more than half of their business going across the water.
For overseas customers in the Middle East, heat and sand thrash everything exposed to the elements. TCS Production Supervisor Steven Plummer equates it to a sandblasting effect.
“When we’re dealing with customers on American shores like refueling stations in Alaska or on naval piers, the meters are out in the saltwater splash,” Plummer says. “These are concerns that will take the paint right off.”
TCS expanded its production to include products made to handle the demand for biodiesel-compatible meters.
After talking to other manufacturers and distributors, and having no luck, Musselman met with the Accessa Coatings Solutions team from Indianapolis. To find the right product for these tough jobs, Accessa Coatings Solutions and TCS carried out a salt spray test, scratch test and many soak tests in which painted products were immersed in biodiesel and ethanol. Musselman says they just sat back and waited for the paint to peel off. In the case of the Accessa Coatings Solutions product, that didn’t happen. They knew they had a winner.
“We tested a lot of products with a lot of labels that you know, but when we found the right product, it was the one that could take care of our customers,” Musselman says.
“It could handle the biodiesel, the salt environments, the ethanol, and it could stand up to being on a truck in an outdoor environment. Once we found that product, we locked in on it and have been using it ever since.”
Low VOC
The Accessa product also fit the bill for having low VOCs, so it was safe for employees to use, but just because the employees had the coating didn’t mean the job was finished.
Bill Adams is the Accessa Coatings Solutions consultant on the TCS account. “One of the unique challenges with TCS was the application process, and we worked very closely with equipment representatives and TCS to be sure we were supplying not only the material, but also the correct way to apply that material,” Adams says.
Ted Mowery is one of the men applying the signature blue shade Adams helped TCS find. He knows the day-to-day problems that come with painting industrial parts. With each custom part and paint application change, there are challenges.
TCS’ flow meters are designed to provide superior performance in custody-transfer measurement of refined fuels, LPG, fertilizers, chemicals, alcohols and solvents.
He can use the same paint and primer, but they will perform differently in different conditions, so Mowery has to be able to tweak the application process to get the finish he’s looking for.
“Ambient temperature and humidity are really big problems, even in a climate-controlled setting, and this paint tends to be pretty consistent and reliable,” he says.
The application process Accessa Coatings Solutions helped develop includes two products. First, a fast-drying acid wash primer is sprayed by HVLP. TCS sprayers then use the Accessa Coatings Solutions INVIRAthane—low VOC polyurethane paint—sprayed either electrostatically or by HVLP at about 3 to 4 wet mils.
Mowery values versatility, reliability, ease of use by the operator and a quick dry time.
“When the customer takes the part out of the box, we want him to know he bought a quality part,” Mowery says.
He relies on Adams to respond quickly to any issues and find answers so TCS customers get what they need. Adams is often on the floor at TCS helping Mowery, Plummer and their team improve. In the rare instance of adhesion issues or application problems, he is there, with an equipment representative if necessary, to help solve the problem so the application process is successfully moving forward.
The meters have to withstand the wear and tear of delivery, often in open-air trucks.
Having the Right Partner
Without having a partner in place to research, test and deliver a complete coatings solutions package that worked, Musselman says TCS would not have been able to successfully expand its production into the petroleum industry. With a partner like Accessa Coatings Solutions at the ready to troubleshoot any problems, issues or concerns, Musselman says TCS can confidently keep growing its business.
“The main thing we want in a relationship with any partner is an open communication line and clear expectations,” he says. “Product availability and consistency are critical to keeping production moving and customers happy. We want an all-hands-on-deck response because our customers expect that and we have to expect it, too.”
For more information: Accessa Coatings Solutions, accessa.com; Total Control Systems, tcsmeters.com.
Cleaning Technologies Group
Precision Cleaning Solvents
vacuum vapor degreasers
Pickelx one step metal prep
Cleaning questions ask Kyzen
Gardner Intelligence
energy
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 10th Quarterly Report
The NASF-AESF Foundation Research Board selected a project addressing the problem of PFAS and related chemicals in plating wastewater streams.  This report covers the 10th quarter of work (April-June 2023).  Here, we examine the effect of surface fluorination of Ti4O7 anodes on PFAS degradation performance in terms of energy performance as well as formation of chlorate and perchlorate when chloride is present in the solution.  The full paper on this work can be accessed and printed at short.pfonline.com/NASF24Feb2.
NASF/AESF Foundation Research Project #120: Electrochemical Destruction of Perfluorooctanesulfonate in Electroplating Wastewaters - April 2022-March 2023
This NASF-AESF Foundation research project report covers project work from April 2022 to March 2023 at the University of Illinois at Chicago.  The overall objective of this work is to utilize a cost-effective reactive electrochemical membrane (REM) for the removal of PFAS from synthetic electroplating wastewater.  Initial results for the oxidation of PFOA with three different catalysts are discussed.
Parts Cleaning
Explore Cleaning Chemistry, Metal Finishing Applications and Wastewater Treatment Solutions
Hubbard-Hall Celebrating 175 years of excellence, Hubbard-Hall presents chemistry and equipment.
nasf
NASF/AESF Foundation Research Project #121: Development of a Sustainability Metrics System and a Technical Solution Method for Sustainable Metal Finishing - 15th Quarterly Report
This NASF-AESF Foundation research project report covers the twelfth quarter of project work (October-December 2023) at Wayne State University in Detroit.  In this period, our main effort focused on the development of a set of Digital Twins (DTs) using the Physics-Informed Neural Network (PINN) technology with application on parts rinsing simulation.
Electrocoating
What’s Next for the Aerospace NESHAP?
Will it be business as usual or are major changes in store for the aerospace industry as feds look at 40 CFR Part 63 Subpart GG, commonly referred to as the Aerospace National Emission Standard for Hazardous Air Pollutants, or NESHAP.
sustainability
Sponsored
