Parts Cleaning Conference
Wastewater Contamination Removal System
Each environmentally beneficial system treats the wastewater stream at a fraction of the cost of larger, more complex industrial systems.
Wastewater treatment
Source: Moonstone Enterprises Inc.
Moonstone systems are ideal for removing suspended solids, emulsified oils, dissolved metals and many other types of contaminants from wastewater, servicing the need for industrial wastewater treatment in a variety of processes.
Each environmentally beneficial system treats a wastewater stream at a fraction of the cost of larger, more complex industrial systems. The Moonstone process occurs quickly and requires minimal operator involvement or supervision.
Moonstone systems have a compact footprint that enables even the smallest of facilities to treat their wastewater, and there is often no need for extra holding tanks or additional chemical treatments.
  • Valence Wichita Receives Processing Approvals for Military Aircraft
    Obtaining these new approvals further expands Valence’s ability to support all Lockheed Martin sub-tier supplier partners in the Central United States from the its central-region locations in Wichita, Kansas and Grove, Oklahoma.
  • Corrosion Protection Via Selective Plating
    Carbon and high strength steels are some of the most widely used metals today, and the corrosion of this type of material is a serious problem for a variety of industries. However, corrosion can largely be controlled with developments in various protective solutions. Sarah Medeiros, Corrosion Engineer at SIFCO ASC, discusses developments in R&D to help slow down the corrosion process.
  • Development of a Novel Hexavalent-Chromium-Free Aluminum Sacrificial Paint
Cleaning Technologies Group
Cleaning questions ask Kyzen
Filtration
