10 Anodizing Best Practices
Following this list of guidelines can help to increase the performance, cost effectiveness and quality for your anodizing operation.
anodized parts
Source: Getty Images
Anodizing is one of the most common surface treatments of aluminum. In all anodizing processes, the basic reaction is conversion of the aluminum surface to aluminum oxide. The aluminum part, when made anodic in an electrolytic cell, causes the oxide layer to become thicker, leading to better corrosion and wear resistance. For decorative purposes, the oxide layer formed on the surface can be dyed. In aluminum anodizing processes, the basic reaction is a conversion of the aluminum surface to aluminum oxide, including Type I (Chromic acid anodizing), Type II (Sulfuric acid anodizing), Type III (Hard coat anodizing).
Below are ten best practices to keep in mind when anodizing:
  1. Surface Preparation: Thorough cleaning of the metal surface before anodizing to remove any contaminants, oils or oxides is imperative. Common methods include alkaline cleaning and acid etching.
      • Learn more: The pretreatment processes prior to anodizing are critical in not only cleaning the aluminum, but also in creating a variety of colors and finishes. Learn more about the effect of pretreatment on the appearance of anodic coating. short.pfonline.com/anodizepretreat
  1. Alloy Considerations: Different aluminum alloys respond differently to anodizing. It is important to keep this in mind when setting finish and performance expectations.
      • Learn more: Alloys with higher silicon concentrations can inhibit the growth of anodic oxide films under galvanostatic and potentiostatic conditions. short.pfonline.com/intermetallicspec
  2. Quality Control: Consistent monitoring of your anodizing process through regular titrations will help maintain the desired coating thickness, color consistency and surface finish.
      • Learn more: Having trouble with spotting defects when anodizing? This overview of the various causes of white spots and potential solutions may help. short.pfonline.com/anodizewhitespots
      • Learn more: Understanding the differences in cracking and crazing in anodic coatings, and insights for mitigating defects in anodized parts: short.pfonline.com/crackcraz
    4. Maintain Anodizing Parameters: Anodizing parameters such as bath temperature, current density and voltage are critical for consistency and quality. Deviations from recommended parameters can lead to uneven coating or poor adhesion.
      • Learn more: Sulfuric acid anodizing bath makeup. short.pfonline.com/sulfanodiz
      • Learn more: The 720 Rule describes the relationship between the amount of current passed through an aluminum surface and the resultant anodic oxide thickness produced over time. short.pfonline.com/720rule
  1. Sealing: Proper sealing helps in closing the pores of the anodized layer and enhances the corrosion resistance and durability of the coating.
      • Learn more: Is a cold seal right for your anodizing operation? short.pfonline.com/coldseal
      • Learn more: Sealing of anodized aluminum is considered to be the most important of all the various steps in the anodizing process. Learn how to select the best anodizing seal process: short.pfonline.com/selectseal
  2. Dyeing: Take care to adhere to proper dyeing techniques to achieve uniform and vibrant colors and make sure the dye is compatible with the anodized coating for long-lasting results.
  3. Racking Considerations: Properly designed and maintained racking aids in achieving uniform coating thickness and prevents uneven coloration.
      • Learn more: What are the most common racking problems for platers and anodizers? This helpful clinic will help you avoid the common pitfalls: short.pfonline.com/rackingpitfalls
  1. Ventilation: Ensure proper ventilation in the anodizing facility to control fumes and maintain a safe working environment. Proper ventilation also aids in controlling temperature and chemical concentrations.
  1. Preventative Maintenance: Regularly inspect and maintain anodizing equipment, including rectifiers, tanks and filtration systems. Well-maintained equipment contributes to consistent anodizing results.
  1. Waste Management: Implementation of effective waste management practices and compliance with environmental regulations is critical for conserving resources, controlling costs and minimizing the environmental impact of the anodizing process.
      • Learn more: Read about one anodizer’s success in conserving water and reducing waste after implementing a zero liquid discharge facility: short.pfonline.com/0discharge
These are just a few tips to help ensure a successful anodizing process with consistent and high-quality results. Always consult with anodizing experts and follow industry standards in order to keep up with the latest advancements in anodizing technology.
Luster-On Products
Gardner Intelligence
Bulk Chemicals, Inc.
PF Podcast
Filtration
Fischer Technology, Inc.
Parts Cleaning Conference
FABTECH 2024
CFS
Anodizing
Anne Deacon Juhl, Ph.D., with AluConsult, says Galvanic corrosion is due to an electrical contact with a more noble metal or a nonmetallic conductor in a conductive environment.
Top Shops
Solving Unmet Needs of the Medical Device Industry
Pioneer Metal Finishing's Medical Center of Excellence has expanded the company's capacity to serve the critical medical device industry. With ISO 13485 certification in hand, the company is now a key driver in medical innovations.
management
Anodizing
Knowing when to switch from chromic acid anodizing to thin film sulfuric acid anodizing is important. Learn about why the change should be considered and the challenges in doing so.
Anodizing
Understanding the Anodic Oxide Finish – The First Commercially Available Nanoscale Coating
Dr. Jude M. Runge is the 2020 recipient of the NASF William Blum Scientific Achievement Award.  The COVID-19 crisis and the cancellation of SUR/FIN 2020 have affected the timing of the formal award and her delivery of the William Blum Lecture.  To honor her properly now, it is timely to publish one of her earlier papers, showing the caliber of her work.  Here, she notes that nanomaterials, nanotechnology and nanoprocessing are the marketing buzzwords for the 21st century, stressing that, after all, conventional anodizing processes yield a nanoscale finish.  Armed with this knowledge, the ease, reliability and reproducibility of the anodic finish enable insights into new applications.
Ask The Expert
Crazing and Cracking in Anodizing
Non-Cyanide Silver Plating, AMS 2411J
