A technician at Aircraft X-Ray Laboratories (Huntington Park, Calif.) applies a chromate conversion coating to aerospace parts in a water wash paint booth. The water filtration system uses circulating water to trap paint overspray, depositing it into a collection tank for periodic removal.
With a long history serving the aerospace industry, Aircraft X-Ray Laboratories has approvals from such companies as Bell Helicopter, Boeing, Lockheed Martin and Northrop Grumman.
The Best Method for Coating Full-Size Aircraft
John Owed from Carlisle Fluid Technologies analyzes the difference between using air-assisted airless, air spray and other technologies for coating a full-size aircraft. Which is better?
