Industrial Finishing Products
Julie Holmquist of Cortec Corporation discusses passivating corrosion on rebar and other reinforcing metals.
Q: I work in the construction industry and am having trouble with preventing rebar from rusting. Can you recommend a corrosion-resistant coating?
A: The ubiquitous problem of rebar rust is hard to escape in the construction industry, but there is a practical answer. As part of Cortec’s High Performance Repair System (HPRS), CorrVerter MCI Rust Primer simplifies surface prep by passivating corrosion on steel surfaces. It is an exciting tool to help the construction industry tackle a recurring challenge.
The Problem of Rebar Rust
Rebar and other reinforcing metals play an integral role in providing the strength necessary to make concrete a viable building material. It is also one of the major causes of concrete deterioration. Although the high initial pH of concrete creates a naturally passive environment that protects metal reinforcement in new concrete, carbonation and cracking can lead to the formation of corrosion products on embedded reinforcement. As rebar rusts, it expands, putting pressure on the concrete cover. This causes more cracking and concrete spalling, deteriorating the structure and eventually requiring repair.
Effective Concrete Repair
For a repair to be effective, exposed reinforcement is typically sandblasted to remove corrosion and promote good surface adhesion to the new repair material. The ICRI 310.1R-2008 “Guide for Surface Preparation for Repair of Deteriorated Concrete Resulting from Reinforcing Steel Corrosion,” states that exposed reinforcing steel should be free of any materials such as concrete, dirt, and corrosion products that could interfere with repair material adhesion, although tightly bonded light rust is usually not detrimental to the bond of patch materials. This opens the door to a completely different level of surface prep convenience using CorrVerter MCI Rust Primer.
A Convenient Solution for the Construction Industry
CorrVerter MCI is a unique formulation of chelating agents combined with a high-solids waterborne latex with extremely low water vapor permeability. This fast-drying, single-component primer converts surface rust into a hydrophobic passive layer and offers excellent protection against re-rusting of metal surfaces. These characteristics are ideal for repairs, making surface prep extremely simple. When using CorrVerter MCI, the first step is to wire brush loose rust off the metal surface. This requires much less labor than blasting and no special equipment. The next step is to remove the excess salt, dust, and contamination by rinsing with water. CorrVerter MCI can then be applied by spray or brush and left to cure for 12 hours before applying repair products. CorrVerter will turn visibly black by the time it dries to touch in about two to three hours.
In addition to increasing the convenience of concrete repairs, CorrVerter MCI is also useful for construction delays where some concrete was already poured, leaving rebar partially exposed to the elements until the project can resume. When the project starts again, CorrVerter MCI is a good way to passivate any rust that has begun in the meantime, thus forestalling additional corrosion problems that could develop as a result.
About the Author
Julie Holmquist
Photo Credit: Cortec Corp.
Julie Holmquist
Julie Holmquist is a content writer for Cortec Corporation. Visit corteccoatings.com.
  • Coatings Plant Evolves with Market Trends
  • Masking Solutions Provider CFS Dramatically Expands Capabilities and Capacity
    Custom Fabrication & Supplies (CFS) completed a new plant expansion packing 10 times the capacity into twice the space. It dramatically enhances the supplier’s custom capabilities to provide extremely precise and cost-effective masking solutions.
  • Robots, AI and Superb BMW Surfaces
    There isn’t an automotive paint shop in the world that doesn’t have post-paint inspection and defect processing. But BMW is doing this with levels of technology at a plant in Germany that exceed all other paint shops in the world.
Precision gear pumps
PF Podcast
Products Finishing 40 Under 40
PMTS 2025 Register Now!
