How to Produce a Visual Blasted Finish
Q. Can you recommend a process that can give a visual blasted finish?
#basics
Q. We are vibratory finishing an aluminum part and then blasting it to achieve a uniform pre-anodized finish. Can you recommend a process that can give a visual blasted finish in our vibratory machine to eliminate the blasting process?
A. Vibratory finishing can produce a visual finish very close to the tight patterned satin reflective blasted finish. Certain vibratory medias, compounds and machines are required.
Featured Content
The high-energy centrifugal barrel works best, but vibratory machines also get close.
The two types of medias that work best in obtaining a blasted finish are a random shape 10- to 16-grit ceramic aluminum oxide media, or a smaller ¼ " to 3/8" polyester plastic cone or pyramid-shaped preformed media.
The random media works the best with both vibratory and centrifugal barrel machines and tends to lodge in holes. The smaller, pre-formed polyester media also works in a centrifugal barrel and vibratory processes. The vibratory compounds affect different surface brightness.
Originally published in the January 2017 issue.
RELATED CONTENT
Aluminum Surface Finishing Corrosion Causes and Troubleshooting
In this paper, a review of several process solutions, examining coolants, solvent cleaning, alkaline clean/etch and deoxidizing/desmutting, listing intended and unintended chemical reactions along with possible mechanisms that would favor corrosion formation.
Zinc Electroplating
