A preventative maintenance schedule can help avoid unplanned downtime and equipment failures.
Photo Credit: All photos courtesy of Therma-Tron-X Inc.
Your industrial oven is an essential component of your finishing line. To ensure your oven is working properly and is in ideal condition, it is important to follow a regular preventative maintenance (PM) schedule. Preventative maintenance is a program that ensures regular and routine maintenance on a piece of equipment in order to keep it running and prevent any unplanned downtime or equipment failures.
Typically, an oven manufacturer will provide you with a PM schedule and checklist. This checklist identifies items that need maintenance and will help to prevent bigger issues by scheduling maintenance that is typically based on operational hours. These checklists can be done by any maintenance personnel; however, they are usually done by the machine operator if properly trained. Having a PM plan in place is the first step in running the facility more efficiently and will help in reducing the cost of operations. The second step is making sure your staff are fully aware of the plan and trained accordingly to carry out the procedures and tasks regularly.
In addition to regular maintenance, it is critical that you have your spare parts list stocked for your oven. Having the spare parts stocked in your facility greatly reduces the chance of unwanted downtime. Along with eliminating unwanted downtime, having stocked parts will eliminate excessive expediting or shipping costs and maintain better client relationships by delivering their product in a timely manner. A spare parts list is typically given along with the PM schedule by the manufacturer.
Inspect Interior of Oven
Electrical Components: When an oven has dirty electrical components, it is not able to disperse heat as well as it should. Having dust and dirt buildup on your electrical components can cause the heaters and circuits in your oven to short out and possibly fail. A few maintenance checks for electrical components include:
- Lubricate motor bearings
- Check all panel indicator lights
- Check all emergency stop buttons for proper operation
- Inspect for discolored or loose fuses
Exhaust System
Dust buildup can lead to malfunction of fans and motors.
Fans and motors: Just like electrical components, when fans and motors are dirty and have dust buildup, they cannot work properly and can restrict the airflow. This will affect the performance of your oven and can affect the overall safety of the oven. In more extreme cases, this can lead to several components failing due to the oven overheating.
When checking the fans and motors it is also important to inspect recirculation, air seal and exhaust fan belts for wear and proper tension. A few maintenance checks for fans and motors include:
- Inspect for loose screws on all guarding
- Inspect ductwork for loose nozzles, screws, and support clips
- Inspect sheaves for wear and proper alignment
Heating Elements
Inspect the burner for carbon or dirt accumulation.
Burners and igniters: When a heating element is burnt out it can cause reduced power, which in turn can mean a loss in performance. By following a PM schedule, these checks will be done regularly, ensuring that your oven is working at its peak performance. A few maintenance checks for burners and igniters include:
- Inspect and clean the flame rod
- Inspect igniters for condition and electrode gap
- Inspect the integrity of the wire terminations
- Inspect the burner surface and gas ports for carbon or dirt accumulation
Regular monitoring of your oven can help determine a filter change schedule.
The PM schedule needs constant monitoring and tweaking. You want to be sure that the assets are being maintained regularly and that any redundancies or unnecessary steps are eliminated. For example, on the manufacturer’s PM schedule, they might recommend changing the filters monthly, but with regular monitoring of your oven, you may find that your oven’s filters are not dirty enough to replace monthly and can stay in for another month or two. If that is the case, the filter change schedule would change to replacing quarterly and not monthly.
When executing a PM schedule there are a few common mistakes that people tend to make. Some employees might not take a PM schedule seriously, which can result in mixed messages and poor communication with staff.
When businesses are transitioning from a reactive maintenance mindset to a proactive, preventive maintenance way of operating, it may take some practice for old habits to die. Working in a reactive environment may be reflected by poor record keeping, multiple spreadsheets and outdated or even worse, no written procedure record keeping of your oven. While this might be the worst-case scenario, having written procedures on how to maintain every item on the PM schedule helps to eliminate costly mistakes and oversights and will ensure your oven is performing optimally.
About the Author
Jacqueline Hilbert
Jacqueline is Sales and Marketing Assistant at Therma-Tron-X Inc. Visit ttxinc.com.
Understanding Infrared Line-of-Sight
Marty Sawyer of Trimac Industrial Systems offers insights into using infrared to accelerate your powder coating curing operations.
Read MoreThe Powder Coating Process
Powder coating is one of the most durable finishes that can be applied to industrial manufactured products, and offers excellent corrosion protection and is very safe because of its lack of volatile organic compounds. To understand the powder coating process you should start with the fundamentals.
Read MorePowder Coating Overcomes Post Forming
Read MoreWicket Ovens Making a Comeback
