Arresting Indoor Air Quality Criminals in Metal Finishing and Chemical Tanks
These so-called ‘criminals’—indoor air quality criminals, that is—can escape from open surface tanks causing irritation or harm to operators.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/PF/Blog/GRU-Shands-Pumps_copy.jpg;maxWidth=600)
Engineering, architecture and consulting firm, Burns and McDonnels' Angela Vawter has an interesting take on ways to improve air quality in metal finishing operations, and also for any shop which has chemical tanks:
"When you think of criminals, the first thing that comes to mind probably isn’t humidity or hazardous mists and vapors. But these so-called ‘criminals’—indoor air quality criminals, that is—can escape from open surface tanks causing irritation or harm to operators, as well as corroding the surrounding building structure and supporting utility systems. Properly ventilating exhaust and supply air of open surface tanks is key to thwarting these fugitives before they can inflict damage—and can ultimately save a company a whole lot of trouble."
To read more of Vawter's take, please click here.
NASF/AESF Foundation Research Project #121: Development of a Sustainability Metrics System and a Technical Solution Method for Sustainable Metal Finishing - 15th Quarterly Report
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 5th Quarterly Report
