Precision cleaning solvents
Aluminum Oxide Impregnation
Question: Having read your article online concerning aluminum oxide impregnation (February 2003), I am curious.
Having read your article online concerning aluminum oxide impregnation (February 2003), I am curious. I grit blast aircraft exhaust systems prior to welding repair using aluminum oxide. I use 36 grit on Type 321 stainless steel to remove the baked on combustion products to achieve a clean surface for TIG welding. Am I getting aluminum oxide impregnation when I clean/blast these parts? Keep in mind that I regulate the air pressure to the gun in the cabinet to 60 psi. M.S.
II cannot say with certainty if you are getting any aluminum oxide impregnation; although I think it is certainly possible. Do you perform any other operations following the blasting? If not, there is probably some residual aluminum oxide, although I am not sure that it will cause any welding issues.
Cleaning Technologies Group
Precision Cleaning Solvents
Pickelx one step metal prep
Cleaning questions ask Kyzen
vacuum vapor degreasers
find masking products online
