Best Coating for 316-SS
Question: What would be the best coating for 316 stainless steel when used around hydrofluorosilicic acid.
What would be the best coating for 316 stainless steel when used around hydrofluorosilicic acid. J. H.
Epoxy powder coatings have the best chemical resistance of most all thermoset coatings. I would try some out by performing a chemical immersion and/or airborne test first before committing to a large purchase of this material. Be sure that the selected coating has all the other properties (appearance, mechanical, corrosion, etc.) that suit your application, as well.
