BLACKENING OF STAINLESS STEEL
We are looking for information on a simple process for blackening of Type 420 stainless steel needles. The blackening should be permanent, corrosion-resistant and medically acceptable. Since the needles are small in size, the method should be capable of processing in bulk.
Q. We are looking for information on a simple process for blackening of Type 420 stainless steel needles. The blackening should be permanent, corrosion-resistant and medically acceptable. Since the needles are small in size, the method should be capable of processing in bulk. M.B.
A. I am aware of one classic formulation that may work for you. The formulation and operating conditions are as follows:
Component/Operating Conditions | Concentration/Range |
Sulfuric acid, | 180 parts |
Water | 200 parts |
Potassium dichromate | 50 parts |
Operating temperature | 210°F |
Two things to keep in mind are: 1) This solution at the temperature specified is rather nasty and must be treated with great care, and 2) Potassium dichromate is a hexavalent chromium compound and may not be acceptable in your facility.
Presumably, your parts could be finished using a basket to hold the needles. If this was my project I would consider using proprietary products. You can find a number of vendors for proprietary products by accessing
www.pfonline.com/plate/index.html and searching the vendor database for Blackening solutions.
Trivalent Chrome Overview
