Industrial Finishing Products
Bright Dip for Stainless Steel
Question: We are looking for a chemical bright dip for parts made of 300 series stainless steel.
We are looking for a chemical bright dip for parts made of 300 series stainless steel. Do you have any suggestions? L.A.
Here is a formulation that may work for you. It was taken from the Electroplating Engineering Handbook, 4th ed., edited by Lawrence J. Durney, Metal Finishing Publications, 914-333-2578.
  • Hydrochloric acid 29.5% (by volume)
  • Sulfuric acid 40.0% (by volume)
  • Nitric acid 0.5% (by volume)
  • Titanium tetrachloride 5.5%
  • Water 24.5%
The solution is used at 160-170F. The dipping time is 2-5 min. The amount of metal removed is approximately 0.0004 inch.
Have you considered electropolishing as an alternative to chemical bright dipping?
Gardner Intelligence
PMTS 2025 Register Now!
Filtration Systems
find masking products online
