CCAI Chicago Chapter Tours Gatto Industrial Platers
The objective was to educate, inform and create an open dialog between platers and coaters with the goal of achieving optimal results.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/GattoPlantTour2016.jpg;maxWidth=600)
On March 15 a contingent of CCAI Chicago Chapter members took part in a tour and Q&A at Gatto Industrial Platers’ facility on Roosevelt Road in Chicago.
The objective of the event was to educate and inform, and to create an open dialog between platers and coaters with the goal of achieving optimal results.
Gatto discussed their process, and led a question and answer period regarding how powder coating and plating processes interact and affect each other, as well as concerns that powder coaters and painters have coating over plating, and how to address resulting issues.
Can You Afford to Not Use Custom Masking?
Are you weighing the costs of a custom masking solution vs. an off-the-shelf solution? Christy Schulthess of Custom Fabricating & Supplies discusses the overall savings that can be realized with custom masking.
Leveraging Technology for Rapid Custom Masking Solutions
When should you consider a custom masking solution? Christy Schulthess of Custom Fabricating & Supplies discusses how today’s technology is putting specialized masking options within reach.
High Temp Alignment Masking Discs
Designed with printed alignment “target” rings for easy application, PCX-SH Series powder peel green discs from Caplugs ensure pinpoint accuracy when centering over any hole.
