Cleaning Ecoat Paint Hooks
Is there a process or substance to keep hooks cleaned without taking them off the paint line?
Q. Is there a process or substance to keep hooks cleaned without taking them off the paint line? We use a process of ecoating, but we lose time taking the hooks off the line to clean them. —M.G.
A. I am not aware of a direct method to strip hooks in place on the line. There are generally two methods for hook cleaning: burn-off ovens or chemical stripping methods. Assuming you are looking for an in-line system, the entire conveyor would likely need to run through the oven, depending on your hook and racking configuration. For this reason, a liquid stripping bath may be preferred for your hooks and racks. Chemical stripping baths fall into two general categories: solvent-based and water/caustic-based. However, unless you either have a power-and-free conveyor system or can “park” one of the racks from a conventional conveyor in one of these tanks for a substantial amount of time (1-3 hours for example), this would also not be helpful to you.
Racks for Powder Coating
Powder coating consultant and PF columnist Rodger Talbert discusses the importance of good racking methods for your powder coating operation.
Troubleshooting 5 Common Racking Problems for Platers
Being aware of usual issues that might occur during the plating process will prepare platers by helping them know how to avoid them all together or how to fix them if they happen.
