Coating Analysis
What are the most energy-intensive areas one can intervene in a standard coating process?
Q. I am a student researching the best way to analyze a painting process, from application to over curing. From your experience, what are the most energy-intensive areas one can intervene in a standard coating process?—S.B.
A. This is a very comprehensive question as it entails many possible variables. Cost analysis is really contingent on the type of operation you want to evaluate. One example: will your analysis be based on manual or automated manufacturing? Evaluate the entire paint process, because each step can potentially have hidden cost, which can affect energy consumption and profitability.
Validation of Coating Materials
What are the paint material requirements, and what energy cost is required to properly apply the material? Why is this important? Coating chemistries are often formulated to accommodate many manufacturing requirements. Be certain the coating used satisfies what manufacturing is capable of profitably producing. These requirements can range from proper viscosity, parts handling, drying perimeters, sanding and more. Failure to identify each of the requirements that a particular coating may need could result in unexpected labor and manufacturing cost.
Validation of Application
What is your transfer efficiency, and why is this important when analyzing a paint process? Transfer efficiency is the percentage of paint material that actually makes it to the surface of the substrate while spraying. Improper spray application and technique can really bring this percentage down due to excessive material waste, not to mention the excessive usage of ventilation and compressed air supply. Even though gun technologies have evolved greatly over the past decade, understanding proper spray gun technology for your application can improve your transfer efficiency from 40-50 percent up to 70-80 percent or even higher with proper training. But the right spray gun technology is only part of the success, as you also need to incorporate proper tip sizes, air pressures, fluid pressures, gun-to-part distance, fan width, triggering and gun speed.
Validation of Drying or Curing Perimeters
What are the temperature and dwell-time requirements for drying/curing the coating material, as energy costs can tremendously impact profitability. Air make-up or not, and why is this important? Without an air make-up system, several things will occur. First you will lose valuable heated air through the exhaust system while you are applying material. Second, in many cases you will create a negative air pressure in the room, which helps to draw contaminants to a wet painted surface. However, adding an air make-up unit will help you recapture and reintroduce continuous temperature-controlled air back into the spray room environment. Air make-up will also help balance out the positive/negative air pressure in a spray room. Again, why is this important? As mentioned, dirt and debris are the enemies of a finish department, and reworks add additional material and labor cost. Independent of each other, material, application and drying/curing do not appear to make an impact on energy consumption and profitability. That is why it is important to analyze the entire paint process. I have found that when you cumulatively make small gains in each area and then combine those gains, you will see a major impact on the energy consumption and bottom line profitability.
PPG Paints, Coatings for Battery EVs Showcased at Germany Battery Show
PPG is attending The Battery Show in Stuttgart, Germany.
Read MoreSpatial Coating Thickness Measurement Solution for Prismatic Battery Cells
Read MoreNASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 10th Quarterly Report
Read MoreAkzoNobel Opens World-First Testing Facility for Wind Turbine Blades
AkzoNobel's state-of-the-art wind turbine blade testing site simulates extreme weather and runs high-speed tests, driving innovation in protective coatings.
