PMTS 2025 Register Now!
Correction on Passivation Specification
Question: In the August issue of Products Finishing magazine you answered a question about passivation from J.
In the August issue of Products Finishing magazine you answered a question about passivation from J. M. You referred him to ASTM A-380 as the standard for passivation. This is a common misconception. A-380 is actually a practices document. The ASTM standard for stainless steel passivation is A-967. A-380 is a good document to read also, but it would be helpful to your readers if you made a correction about this in the next issue of the magazine and the online version of J. M.’s letter as well. R.K.
You are correct that the A-967 is the actual specification while the A-380 is the standard practice. I correctly referred to A-380 as a standard practice and recommended it since, in my opinion, it contains much more information and background than the A-967 specification. Ideally they should be used together.
Luster-On Products
Gardner Intelligence
Filtration Systems
find masking products online
