Non-cyanide alkaline silver plating, mobile app
Functional Coatings for Oil and Gas Production
Oil and gas coatings including ecoat are critical for protecting equipment against corrosion.
Strainer body for oil/gas production with Zpex coating
Source: Products Finishing
The oil and gas industry exposes valves, pumps and pipelines to some of the harshest environmental conditions. Avoiding devastating failures, spills and cleanup costs is crucial for protecting the environment. Ecoat.us is a leading applicator of electrodeposition protective coatings, also known as electrocoating (ecoat). The company has 20 years experience developing patented coating solutions for oil and gas applications including ZPEX, a revolutionary coating system offering complete corrosion protection without over-machining or masking. The company says the coating is thin enough for threads and sealing yet strong enough to replace stainless steel. Pictured here are a strainer body for oil/gas production (above) and a high pressure oil/gas well head valved (below) featuring ZPEX coating. Ecoat.us has four locations that offer Zpex coating: Seminole Okla., Tulsa Okla., Mission Texas and Cleveland Tenn.
Hi pressure oil/gas wellhead valve with Zpex coating
manufacturer of E-coat systems
Metal Pretreatment Technology
PF Podcast
Gardner Intelligence
Products Finishing 40 Under 40
PMTS 2025 Register Now!
