Magnesium Treatment Part 2
I just wanted to forward some comments regarding the question on Mg that appeared in the October issue.
I just wanted to forward some comments regarding the question on Mg that appeared in the October issue. Your answer hit all of the key points, with e-coat/powder and anodizing being the most favorable. Depending on how critical the application is, a chromate conversion coating prior to e-coat and powder coating may be necessary to prevent excessive creeping under any scratches or defects. The former McDonnell-Douglas helicopter group (now part of Boeing) designed a Mg transmission housing and found that maximum corrosion performance after 1,000 hours of salt spray was produced by the following:
  1. Heavy coating of Tagnite (plasma anodizing technique)
  2. Three layers of Rockhard (baked phenolic sealer)
  3. Basecoat of epoxy/polyamide (containing strontium chromate)
  4. Topcoat of polyurethane (chromate free)
More information can be obtained by using www.tagnite.com/boeingreport.pdf
Feel free to pass this information along. I always enjoy reading your column, as well as the others that are featured in PF. Keep up the good work. Best regards. T.P.
Luster-On Products
PF Podcast
Metal Pretreatment Technology
Filtration Systems
find masking products online
PMTS 2025 Register Now!
Non-Cyanide Silver Plating, AMS 2411J
