Mass Finishing to De-sharpen Extrusion Burrs
This part is sharp and we need to dull the edges for handling. What finishing process do you recommend?
Q. We have a large quantity of 6063 aluminum extrusions that we are cutting to length (4" × 4" × 6"). This part is sharp and we need to dull the edges for handling. What finishing process do you recommend? —K.S..
A. Vibratory finishing with semi-automatic- or fully automatic-unload vibratory bowls will do the job. De-sharpening the extrusion with ceramic media will take about a 4-6-minute process. This may not completely deburr the part, but it will de-sharpen it for handling.
It’s a matter of selecting a size and shape of ceramic media for your extrusion. The media shape must get into the areas that need de-sharpening while staying out of areas in which it could lodge. The media size should be a different size than the part. This allows part/media separation so the parts can be unloaded from the machine.
The vibratory bowl machine can either be a continuous process that accomplishes the 4-6-minute cycle times or a batch automation process that accommodates the amount of parts required. Both systems can process parts coming straight from the cut-off saw if need be.
Nadcap Discusses Efficacy of Pneumatic Needle Peening for Repair of Aerospace Parts
Supplier accreditation in this emerging technology is now attainable as part of the Nadcap process.
