Precision gear pumps
Moly Alloy Cleaning
Question: Does the acid solution used in cleaning Moly cause any embrittlement of the moly?
Does the acid solution used in cleaning Moly cause any embrittlement of the moly? If so, how is it removed? Thanks in advance for your help D.L.
I am not aware of hydrogen embrittlement taking place with molybdenum. After looking into it, I do not see an issue. Considering applications for this refractory metal include reducing atmospheres and acids, I cannot see it being a problem. Since the typical operation to remove the embrittlement is rather long (300°F for 2-24 hours), it is worth exploring. I would check with your metal supplier. If it is a service center, have it try to get back to the actual metal producer, since it should be able to definitively answer your question.
PMTS 2025 Register Now!
find masking products online
PF Podcast
