Painting Brass
Question: I have a design that requires the use of brass (No. 360 copper alloy). This design requires that some portions be painted (epoxy primed and polyurethane topcoated). I have no experience painting brass and/or know if this alloy is even “paintable.” Could you provide some insight into this matter and recommend how to best prepare the surface for painting?
I have a design that requires the use of brass (No. 360 copper alloy). This design requires that some portions be painted (epoxy primed and polyurethane topcoated). I have no experience painting brass and/or know if this alloy is even “paintable.” Could you provide some insight into this matter and recommend how to best prepare the surface for painting? P.S.
Painting brass is a piece of cake if the surface is properly prepared. As with cake, brass pretreatments come in different flavors. However, all cakes start with batter, and all brass pretreatments start with cleaning.
Brass can be cleaned using solvents, aqueous chemicals or emulsions. The metal must be cleaned to remove oily soils that would otherwise act as an interference coating, hampering paint adhesion. After cleaning, pretreatments to remove corrosion products can be applied.
One such brass pretreatment is bright dipping. This is done by immersing the brass in an acidic solution. Bright dip solutions are available from electroplating chemical suppliers. Suppliers of bright dips can be found at www.pfonline.com on the Suppliers page and are listed on pages 342-343 in the 2000 Products Finishing Directory.
Brass can also be pretreated by abrasive blasting. Suppliers of abrasive blasting equipment and materials can be found at www.pfonline.com on the Suppliers
page and are listed on pages 309-314 of the PFD.
As I mentioned in a previous Painting Clinic, people who coat copper and brass wire “pre-anneal” before coating. The wire is passed through a high-temperature steam chamber with an inert gas atmosphere to exclude oxygen and eliminate any explosion. The hot wire is then quenched before coating.
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 7th Quarterly Report
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 5th Quarterly Report
