Plating Line Opens Waste Treatment Opportunities
At Standard Aero Ltd. the decision to install a chromium plating facility and on-site wastewater treatment system offered an opportunity to assess waste handling in other areas of the plant.
At Standard Aero Ltd. the decision to install a chromium plating facility and on-site wastewater treatment system offered an opportunity to assess waste handling in other areas of the plant. The aircraft engine and component overhaul/repair facility in Winnipeg, Manitoba, Canada, is now getting double duty from its wastewater treatment system. The system, intended only for plating rinse waters also treats concentrated wastes from departments that had previously had them hauled away as hazardous waste.
Standard Aero's story is bound to be repeated many times over as plating industry executives factor in the growing roles of environmental compliance, water use, resource reuse and waste minimization in plant economics. The emphasis is on treatment technologies that can be applied to variable waste streams, plant designs that allow one waste stream to play off another during the treatment process, and other methods of making compliance pay.
Designed and built by Beckart Environmental, Inc., Kenosha, Wisconsin, the wastewater treatment system went on-line simultaneously with the company's new plating department. The department primarily handles chromium, but also silver and copper plating on various aircraft components, as well as cadmium stripping.
Typically, rinse waters and scrubber water containing chromium, cyanide and various acid streams are collected in two pits located below the plating line. The maintenance schedule is two to three scrubber wash downs per day using 50 gal per wash, so the water is highly concentrated.
Chromium and cyanide destruction are accomplished in separate two-step processes involving adjustments in pH and chemical reactions with sodium metabisulfite and sodium hypochlorite, respectively. These reactions convert cyanide to cyanate, and chemically reduce chromium from its hexavalent to trivalent state. Secondary reactions are the oxidation of cyanate to carbon dioxide and nitrogen and the neutralization and precipitation of the trivalent chromium.
A programmable logic controller (PLC) makes all chemical and engineering decisions within the treatment system, regulating critical reaction times, monitoring and adjusting pH, and metering treatment chemicals. The PLC also controls transfers from equalization tanks to treatment tanks, sedimentation clarifier and filter press.
In addition to the equalization tank dedicated to the plating line, a second equalization tank is used for spent concentrates brought by drum from various parts of the plant. Cooling water from plant compressors and rinse waters from an anodizing line are used to dilute the concentrates. Spent acids from the plant are also added to help neutralize the highly alkaline solutions. The treatment scheme incorporates some waste streams in the treatment of others while minimizing overall water consumption.
According to Standard Aero process engineer David Ronson, the new wastewater treatment system was selected primarily because of the technologies involved, the comprehensive design and the ability of the manufacturer to assist when wastewater treatment requirements change.
Mr. Ronson noted that the system's 20 gpm sedimentation clarifier, originally designed for operation 20 pct of the time is currently operating about 60 pct of the time. Standard Aero has increased the system's filter press capacity as its needs have grown, and the company is now generating about three tons of sludge monthly. The company is considering sludge drying equipment that would further reduce disposal costs
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 9th Quarterly Report
Read MoreNASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 7th Quarterly Report
Read MoreNASF/AESF Foundation Research Project #120: Electrochemical Destruction of Perfluorooctanesulfonate in Electroplating Wastewaters - April 2022-March 2023
