Powder Coating ABS Plastic and Teflon
Is there a method of powder coating that would be applicable here and would not melt the hubcap? Where do you suggest I go to find out more about the possibilities and limitations of such a process?
Q. I am doing research on different ways to paint hubcaps (ABS plastic and Teflon®). Currently, we use only liquid paint but are looking into the possibility of using powder paint as an alternative. Is there a method of powder coating that would be applicable here and would not melt the hubcap? Where do you suggest I go to find out more about the possibilities and limitations of such a process? J. D.
A. Powder coating of certain plastic substrate has been performed for the last 5+ years. The only restriction is that the plastic substrate must be able to withstand 250°F to melt the powder coating onto the surface prior to UV curing. If your hubcaps can withstand 250°F without melting, then you should continue your investigation into powder coatings. If your plastic falls short of this temperature requirement, then look elsewhere for your coating needs.
Trends in Industrial Coatings
