Powder Coating Clinic: Making Powder Lines More Profitable
Q. We run a job shop powder coating operation with a conveyor system that runs at around 4 to 6 fpm, depending on what product is hung. We are putting through a lot of work, but our profits are not great. Can you suggest how to improve the efficiency, or cut our cost for a better profit margin? We cannot speed up the line because we do not have enough time in the cure oven to go faster. Our powder material cost seems to be higher than what we expect based on our quotes. What are we missing?
![](https://d2n4wb9orp1vta.cloudfront.net/cms/Roger_web.jpg;maxWidth=600)
A. Start by reviewing your quoting practices. You need to break down your racking scheme and make sure you understand the actual production rate. Gather all your costs (labor, material, fixed business cost, line burden, scrap and rework, etc.) and divide it out by the production rate to get an accurate per-piece price based on the production rate. Then you will know your real cost per part and be in a good position to add the profit margin you need.
Another issue that I always point out is racking. The conveyor speed is one aspect of throughput but the more important issue is “how full is the line?” Pay attention to spacing in the vertical and horizontal. Be aware of improved positions or density. As long as the coaters can keep up with the amount of surface going through the booth, it is a good idea to rack parts densely. You may want to invest in special racking for some parts so that they are hung at the optimum density. Simple hooks are useful but sometimes they do not take proper advantage of the available space on the line.
Operator technique and film build control are also key issues. Be sure your operators have the proper training and understanding of what to coat, how to use the gun and how much powder is needed to achieve the desired performance. If they are not efficient or you have too many rejects, the cost of coating is artificially high. Check film build regularly.
Color change is also a factor in some lines. Limit color change frequency and work on short color-change time by training your people and using the best equipment available. Plan production to minimize downtime and lost powder. Maintain your system by scheduling cleaning and repair and keeping things in good working condition. Damaged or worn system components reduce efficiency and raise cost. Keep spare parts inventory and make sure the guns are always in good working order.
Check your earth ground to make sure that your parts are always grounded during coating. Poor grounding will increase rejects (hook scars, light coating, orange peel) and decrease application efficiency. Use good powder products. Some coaters shop for lower cost powder by the pound. Focus on applied cost, and that may mean using a material that costs more per pound but covers more surface because of better ingredients. Not all powders are created equal.
Make sure the people that run the line are trained and motivated, keep the system in good condition and maximize output. Use the line for optimum throughput, and you should be making money.
Originally published in the December 2016 issue.
Wicket Ovens Making a Comeback
Read MoreCatalytic Gel Ovens Offer Small Operational Footprint
WolfRayet catalytic gel ovens offer small operational footprints while also providing a way to improve on existing convection curing.
Read MoreHow Not to Cure Powder on MDF
