Recoating a Permanent Structure
What can be applied that will match the color and texture of a powder coat finish?
Aluminum Railing
Q. I am a faux painter and have been unable to find a solution to a possibly unique problem with a powder coated aluminum outside railing. A square-tube, aluminum railing was powdered coated when new (less than three years ago), then permanently installed in an outside setting in a mountain location. Over the winter, the tubing filled with water and froze, causing expansion in the aluminum, which resulted in the powder-coated finish peeling in several places.
Unable to contact the one who originally applied the coat, the owner has called several painters and me (a faux painter) to try to repaint the bare aluminum patches with a similar finish. No one will tackle the project. I have done some research on your web site, but cannot find a solution to this problem.
Keeping in mind that the railing is not removable and must be painted in place, what can be applied that will match the color and texture of a powder coat finish? Is there a way to apply powder coat again while the railing is in place? If the bare spots are painted with something like Krylon, can that be feathered into the existing finish or be safely applied over the existing finish? I am sure that even if the aluminum is primed, the repair will not be as durable, and there will be other potential problems. However, there must be some way to fix this! Your reply is appreciated.
A. How interesting…a faux painter….Hmmn. I have been accused of being a faux consultant, so I sympathize with your predicament. Of course, I am just kidding. No cards and letters please.
Let me first explain the causation of the powder coating failure. The coating did not fracture by the aluminum tube freezing or expansion either. Powder coatings are very flexible materials and can often take a zero T-bend without fracture. Powder coated parts can even be deep drawn after powder coating (up to six inches and sometimes more). What happened was the powder coating was applied to a poorly cleaned and pretreated surface. The powder may also have not been fully cured. Either way, moisture penetrated the coating, combined with salts and contaminants on the substrate and created a corrosion site that eventually lifted the coating by osmotic pressure. This is a common problem when the process has not been performed properly. It is simply called adhesion loss (or blisters) caused by corrosion failure of the coating.
This failure means that spot fixing the powder coating can be problematic since the adjacent areas will most probably fail, as well. The only bulletproof way of fixing this problem is to completely strip all the powder coating from the part before re-coating the railing. Since the railing is “permanently” installed, this means stripping the powder by grit blasting or sanding. Then I recommend that the surface be wiped clean with a tack rag, primed and top-coated using a two-part polyurethane liquid paint.
Now you see why the other contractors wanted no part of this repair. If you can’t do this repair procedure exactly like I described, or are unfamiliar with two-component liquid paints, then there is only one thing you should do: Run away as fast as your little faux feet can take you. That may sound condescending, but it is the best advice that anyone can give you.
Steel Siding
Q. I read your article about re-coating a permanent structure. I too have a permanent structure that needs “brightening up.”
Our building, a warehouse, is sided with what appears to be powder coated steel siding typical of metal buildings. The building is 20 years old and the siding is still in perfect shape. There’s some oxidation, but aside from that, the surface is in excellent shape. Must be the Colorado air.
We want to repaint the entire building, about 30,000 sq. ft of floor space, to change the color and brighten up the appearance of the structure. We have considered using the one-part epoxy floor paint we have used on the floors with remarkable success. The paint is one-part, but requires a primer. The price of this durable paint is also reasonable.
Any guidance is appreciated.
A. As the original columnist for the article you cite, I’d like to try to tackle this question. Although obviously, powder coating isn’t a process that can be employed here, and unless it’s my own house, I’m not an expert in painting buildings!
However, like most people, I have opinions on topics that I don’t have direct experience with, or even very much knowledge of. (I tell you this because it should directly influence how much credence you give my answer.)
It’s my advice that you not use an epoxy floor paint, as this formula is not made for use outdoors. It will chalk in a couple of months and look like bad aluminum siding. If you want to paint this building, tell your contractor to use a two-component urethane. This material is better suited for this application and is easy to purchase, mix, and apply. Lastly, urethanes are very durable and UV-resistant and should provide a very long service life in this application.
Conveyors and Paint Systems
Read MoreCuring Oven Basics
Read MoreReduced, Reused and Recycled Powder Coatings Are the Future
