Removing Flash and Parting Line
Question: I am looking for an efficient way to remove flash or create a "uniform" parting line on numerous cosmetic parts that are zinc die cast.
I am looking for an efficient way to remove flash or create a "uniform" parting line on numerous cosmetic parts that are zinc die cast. The parts will be powder coated or plated. Would vibratory finishing work? Do you have any suggestions? K.O.
Some sort of mechanical finishing would be required to remove that parting line. Vibratory finishing may help but first may require grinding to remove the bulk of the flash.
Trends in Industrial Coatings
