Spray Booth Selection
I would be obliged if you could advise me on which of the following two spray booths is best for my application.
Q. We are in the process of setting up a painting system for our products. Our application involves spray painting of large castings 3 × 2 × 1.8 m in size and spray painting of medium castings 2 × 0.5 × 0.1 m. I would be obliged if you could advise me on which of the following two spray booths is best for my application:
1) Down draft booth(air in from top and out from bottom; with a pit for exhaust air, or
NASF/AESF Foundation Research Project #120: Electrochemical Destruction of Perfluorooctanesulfonate in Electroplating Wastewaters – January – December 2023
