Stripping Copper Plate from Steel
Is there a way to remove copper plate from an assembled part?
Q. We have copper-plated SA-675 carbon steel components that are welded to a larger steel assembly. We have now learned that the end user of these parts will not allow the use of copper-plated components. Is there a way of removing the copper plate from the assembled part? –C.J.
A. Copper plate can be removed from steel using chemical stripping solutions, but I don’t personally prefer to use them for two reasons: 1) There is a high risk of etching or otherwise damaging the base material if the process is not carefully controlled, and 2) there is a risk that you won’t remove all of the plated deposit.
The most common chemical stripping method uses the following chemical solution:
Chemical Component |
Concentration* |
Chromic acid |
250 g/L |
Sulfuric acid |
2.5 g/L |
*Operating temperature: 120o to 130oF
Another procedure that is sometimes used involves the following:
Concentration** |
Ammonium persulfate |
50/g/L |
Ammonia |
15 ml/L |
**Operating temperature: 75o to 80oF
Both methods use materials that require great care. Your best bet, in my opinion, is to scrap the parts and start over!
