Tackling Common Cleaning Challenges
These four cleaning problems have practical solutions that, when followed properly, can be successful.
Achieving top-notch cleaning results is vital for ensuring product quality, performance and durability for metal parts. The cleaning process removes contaminants such as oils, metal shavings and residues that can compromise component function. However, manufacturers often grapple with challenges that can make achieving the desired cleanliness specifications difficult. The following four typical cleaning challenges have practical solutions to conquer them head on.
1. Component complexity. Metal parts often feature intricate designs with deep recesses, blind holes and thin channels that trap contaminants, making them tough to clean thoroughly.
Solution: Precision cleaning techniques. Both aqueous and vapor degreasing cleaning methods are highly effective at cleaning metal parts with complex geometries. Aqueous cleaning uses water-based solutions combined with agitation, heat and sometimes ultrasonic technology to remove contaminants. On the other hand, vapor degreasing uses solvent fluid and vapors to reach deep recesses, blind holes and tiny channels. The vapor's ability to condense on the cooler surfaces of metal parts penetrate hard-to-reach areas and dissolve contaminants without leaving residues.
Reaching stringent cleaning specifications is possible with different types of cleaning methods when implemented correctly. Source (all): MicroCare LLC
2. Diverse contaminants. Metal components often accumulate a variety of contaminants, such as oils, greases, metal shavings, oxides, waxes and flux residues. These contaminants can be deeply embedded in crevices, on complex surfaces, or within tight channels, making them challenging to remove. Each type of contaminant may necessitate a specific cleaning technique and fluid, which can complicate achieving consistent cleanliness.
Solution: Tailored cleaning processes. To address this complexity, manufacturers should start by conducting a thorough analysis of the contaminants present on their parts. This enables them to select the most effective cleaning methods tailored to the specific contaminants. For instance, aqueous cleaning is highly effective for removing water-soluble contaminants like coolants and cutting oils. In contrast, vapor degreasing is superior for eliminating non-water-soluble contaminants that are often challenging to remove with aqueous methods.
3. Equipment limitations. Outdated or insufficient cleaning equipment may not provide the temperature control, agitation or precision needed to remove stubborn contaminants effectively.
Solution: Upgrade and customize. Investing in modern, high-performance equipment and fluids enhances cleaning outcomes by offering precise control over key parameters such as temperature, agitation and cycle time. This enables tailoring the process to each part's needs. Regularly monitoring and adjusting the cleaning process ensures consistent exacting standards, regardless of contaminants.
For more demanding applications, manufacturers should collaborate with specialized equipment and precision cleaning fluid suppliers to develop custom solutions. For instance, vapor degreasing fluids can be specially formulated to match specific materials and contaminants, while equipment enhancements such as ultrasonics or spray wands can boost cleaning effectiveness.
Vapor degreasing is superior for eliminating non-water-soluble contaminants such as heavy greases, waxes and flux residues.
4. Environmental and Regulatory Considerations. Metal parts manufacturers must also navigate environmental and regulatory considerations when selecting and implementing cleaning processes. Many traditional cleaning methods, such as those using outdated solvents, like nPB or TCE, can have negative air quality impacts and may be subject to strict regulations. Compliance with these regulations can add complexity to the cleaning process and may limit the use of certain cleaning agents.
Solution: Go green. Manufacturers can address environmental concerns by opting for eco-friendly cleaning options. Aqueous cleaners are favored for their low toxicity and easy disposal, especially with biodegradable agents, though they often require longer drying times and more energy-intensive processes. In contrast, modern vapor degreasing fluids are designed to have a lower environmental impact than their predecessors, with low global warming potential (GWP) and non-ozone-depleting properties. They work efficiently in closed-loop systems, minimizing emissions and reducing waste. By staying informed about regulations and investing in advanced cleaning systems, manufacturers can ensure compliance and combine their effective cleaning standards with responsible environmental stewardship.
About the Author
Elizabeth Norwood is a senior chemist at MicroCare, LLC. She has been in the industry more than 25 years and holds a bachelor’s degree in chemistry from the University of St. Joseph. Norwood researches, develops and tests cleaning-related products. She currently has one patent issued and two pending for her work. For more information, visit microcare.com.
Trivalent Chrome Overview
Read MoreLiquid Chrome Vs. Chromic Acid Flake
Read MoreTroubleshooting Alkaline Zinc
One of the most common problems that can arise when plating with alkaline zinc is an imbalance of brightener in the solution. In this helpful Ask the Expert article, Chad Murphy of Columbia Chemical discusses how different zinc metal concentrations and brightener concentrations can impact efficiency.
