Thin Parts Stick Together
The process is acceptable, but the problem is that the parts stack together in the vibrator, and about 15 percent of them have to be reprocessed.
Q. We make small, arched, spring steel pieces that are 2 × ¼ inches from 0.022-inch stock. The arch height is 0.22 to 0.24 inch. We debur the edges in a three-foot bowl vibrator using 3/8-inch angle cut cylinders. The deburring cycle is three hours, and we remove the parts using a handheld magnet; the parts are degaussed prior to inspection. The process is acceptable, but the problem is that the parts stack together in the vibrator, and about 15 percent of them have to be reprocessed. We add a grit to help to break up the stacks. Before we were adding the grit, the rework rate was about 30 percent. What changes can we make to improve this operation? P.J.
Engineered Shaped Grain Abrasives Take Grinding Productivity to New Heights
Wall Colmonoy Hires Business Development Manager, Surfacing Products
Wall Colmonoy welcomes Josh Gardner as its business development manager of surfacing products.
