A Primer on Filtration
Question: I need some basic information on filtration as it applies to plating baths.
I need some basic information on filtration as it applies to plating baths. Where can I find some information? B. J.
There is lots of information out there on this subject. The best place to start is to pick up your copy of the Products Finishing Directory & Technology Guide and read the article on Solution Filtration . You should also go to the above mentioned web site and do a search on the term solution filtration. You will find a number of good articles available on filtration.
Zinc Electroplating
