Addressing Problems With Carbon Treatment for Nickel Tanks
Getting defects after performing carbon treatment and maintenance? Josh Fish of Pavco Inc. offers insights for mitigating problems that might arise from carbon treatment for nickel tanks.
Q: We just performed our yearly carbon treatment and maintenance for our nickel tank and now we are having problems. We see defects in the deposit that look like cracks or raised lines in the deposit. This defect is seen across most of our part numbers and is currently at 25-30%. The defect also sometimes goes horizontal and sometimes vertical. We have evaluated the substrate and do not see anything there. Also, when we strip the nickel, the defect goes away. Something bad like this always seems to happen after our treatments and I am starting to question if we should stop them altogether. What are we doing wrong and what could be causing this defect?
First, we should discuss the “why” behind doing a carbon treatment on a nickel tank. Nickel baths will build up with organics from multiple sources. Those include good organics from your carrier and brightener package, bad organics from electrolysis (breakdown products of the good organics), bad organics from drag in from previous tanks on the line, and finally from soils/oils/greases/buffing compounds that are not always removed during the cleaning process. As the organic load in the bath increases, you can see detrimental effects to the deposit characteristics like increases in stress and reduction of ductility. You can also start to see visual defects on the work such as hazing in the MCD-LCD areas, and organic pitting. Because of these negative effects, regular carbon polishes, treatments, and maintenance should be done on the bath to ensure that you are producing a quality finish. Many platers will track the total organic carbon (TOC) in their nickel baths to determine when they need to be treated, while others will schedule the treatments at the same time every year.
When doing these treatments most platers take the time to do other maintenance on their tanks like removing sludge from the bottoms of the anode baskets and replacing anode bags due to iron (Fe) buildup or rips/tears. Based on what we know about the defects looking like small lines/cracks or even described as “hairs” or “fibers” in the deposit, a common source of the problem is anode fines from the nickel sludge or fibers from the anode bags. The best practice for removing anode fines is to remove the baskets from the plating tank to an offline position, remove the anode bags and then pressure wash the basket to remove the fines. This way you eliminate the possibility of spraying fines into the tank. Also if the anode bags are not treated properly before putting them on the baskets, they can then release fines or “sizing” into the bath. The best practice for new anodes bags is to wash them using a slightly alkaline solution (like 10% sodium carbonate). Then rinse the bags with water before soaking them for 8-24 hours in a 1% sulfuric acid solution with 0.1% nickel wetting agent. This will clean the bags of any potential organic contaminants that you can get from the sewing process of the bags and remove any loose sizing from the bags.
To evaluate this hypothesis, you can take two gallons of the plating solution and vacuum filter it in the lab with one gallon being filtered through a white filter paper and the other gallon through black. By filtering this way, you can see if you have any particulates in the bath that could be co-depositing with the nickel creating this roughness. The white paper will show you particulates like carbon or dirt, while the black paper can show you filter aid or the sizing material from the white anode bags. You can also send a part showing the defect to your chemical supplier for defect analysis to help you get a better understanding of what is happening.
Unfortunately, if you do have particulates from any source (anode bag fibers, carbon/filter aid, anode fines, etc.) then you are at the mercy of your filtration system to remove them. If you need the production and can handle the current scrap rate, then letting your filtration run and continuing to plate will allow you to eventually “walk out” of the problem. How quickly it corrects itself will depend on the amount of particulates in the bath, the speed of your filtration (bath turnovers per hour), and the layout/design of your filtration system. If you are running critical parts and cannot afford the increased scrap rate, the best course of action would be to pump the entire tank out to storage through your filter and then clean/inspect the entire tank including checking the anode bags for rips/tears. Then change the filter pack and pump the solution back to the plating tank through the filter. This way the entire plating bath gets filtered twice and therefore any particulates should be removed.
About the Author
Improving Leveling in Nickel Systems
Chad Murphy of Columbia Chemical offers insights for addressing issues with leveling in nickel systems.
Read MoreAvoiding Roughness and Pitting in Decorative Bright Nickel
Doug Lay of Coventya Inc. offers a troubleshooting guide for avoiding roughness and pitting in decorative bright nickel processing.
Read MoreEpisode 11: Weathering the Supply Chain Storm, Part 2 - Metal Plating
Douglas Hughes, product manager wear resistant coatings for MacDermid Enthone Industrial Solution discusses the current supply challenges facing the finishing industry.
