All-in-One pH, ORP and Temperature Probe
Digital probe is designed to withstand aggressive chemical, water and wastewater environments.
![pH, ORP and Temperature Probe](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/pf/2021-pf/alar-m4-knick-smaller-1.png;maxWidth=720)
Monitor pH, ORP and temperature all in one robust, pre-calibrated probe. ALAR’s digital probe is designed to withstand aggressive chemical, water and wastewater environments. The digital signal eliminates analog “noise” and transmits up to 300 feet. The monitoring system datalogs readings and sends calibration or failsafe alerts to the PLC. ALAR offers automatic self-cleaning probe holders that insert the probe into the tank when processing, then retract to flush and submerge the probe with city water (allowing the tank to be empty). An operator can quickly replace a probe without process interruption or exposure.
ALAR Corp. | 708-479-6100 | alarcorp.com
Pretreatment for Painting
