Back to the Old Grind
Question: Sir, I have purchased a granular powder that is a heat resistant additive and has to be added into the paint as 20% addition.
Sir, I have purchased a granular powder that is a heat resistant additive and has to be added into the paint as 20% addition. However, with cement paint and enamel, it gives a good heat resistance property but does not give a good finish. Can I smash the granules to a finer size to get a good finish? B. B.
Yes you can smash (grinding to reduce the particle size) the granules to a finer size, but that will not necessarily guarantee a smoother finish. When we old paint chemists talk about making paint the operative word is grinding. Paint is ground during manufacture using various machines such as ball mills, sand mills, three roll mills, spinning blades and colloid mills using grind stones to grind the pigments (powders) into the vehicles (liquids). The liquid and powder portions are premixed and then ground to a predetermined fineness. Furthermore, the addition of 20% of a powder to an existing paint is substantial and could result in a severe gloss reduction. You may be able to stir in your powdered ingredient after smashing it, but best results will be obtained by grinding it into the paint. If you don’t have the equipment, your must have it done by a paint manufacturer.
Nanostructure of the Anodic and Nanomaterials Nanoparticles in Polyelectrolyte Multilayer-by-Layer (LbL) Films
NASF/AESF Foundation Research Project #123: Electrochemical Manufacturing for Energy Applications - 9th Quarterly Report
This NASF-AESF Foundation research project report covers the ninth quarter of project work (January-March 2024) at the University of Texas at Dallas. In this period, we followed our work on 3D printing anode support for solid oxide fuel cells, SOFC (or cathode for solid oxide electrolyzers, SOEC). We focused on the mechanical properties of 3D printed yttria-stabilized zirconia (YSZ) using a four-point bending test. We then conducted a statistical analysis to characterize the flexural strength of porous 3D printed YSZ. The full paper on the ninth quarter work can be accessed and printed at short.pfonline.com/NASF24June2.
ProPlate Uses Pure Platinum and Gold in Additive Plating Process
The company says pure gold and platinum are superior at conducting electricity and have other performance advantages compared to platinum-iridium alloys and stainless steel.
