Cleaning Up Slot Cars
Question: I have a slot car track with a lot of rust on the end terminals that connect the two pieces together. (They are small pieces about 1/8-inch long, very fragile). Have you ever been a slot car HO racer?
I have a slot car track with a lot of rust on the end terminals that connect the two pieces together. (They are small pieces about 1/8-inch long, very fragile). Have you ever been a slot car HO racer? What do I need to remove rust? Thank you. J.H.
Since most of the questions to this column deal with industrial products and chemicals, I will have to keep in mind that you have a limited supply of possibilities available to you around the house (and try to remember what my slot cars used to look like when I was younger). I would suggest trying to dip the very ends of the terminals in lemon juice. The citric acid will do a good job at removing most corrosion products. If there is too much corrosion on these terminals, it is possible a carbonated soft drink would also work. These contain phosphoric acid, and I have seen them used at times as a household de-rusting agent. Obviously, you need to be careful to only expose the end terminals to either solution and not let the liquid come in contact with the remainder of the car.
Dodge Notes the “Last Call” with Power—and Paint
As the Dodge Charger and Challenger leave the lineup, the muscle car purveyor is putting out the final vehicles and offering paints from the cars’ performance past.
Tin and Tin Zinc Overview and Growth
Brett Larick of Columbia Chemical discusses the increasing demand for conductive finishes driven by the increasing electrification of vehicles.
