Having a Blast: Best Practices for Media Blasting
5 considerations for media blasting as surface preparation for coatings.
![media blasting](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/pf/2024-pf/0924-pf-askexpblastlr.jpg;maxWidth=720)
Q: Can you recommend some best practices for media blasting?
A: Media blasting is a commonly used technique in surface preparation, especially prior to coating or finishing. It involves propelling abrasive materials against a substrate to clean, smooth or shape it and improve adhesion for coatings. Here are some important considerations to keep in mind when using media blasting as surface preparation for coatings:
![](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/PF/2024-PF/blastmedia-qrcode.png;maxWidth=385)
Which blasting media should you use?
The selection of the right abrasive material is crucial for success when media blasting. Different types of abrasives will be more suitable for some surfaces and/or coatings than others. For example:
- Steel grit is a good choice for heavy-duty cleaning and surface profiling.
- Aluminum oxide is a good option for aggressive cleaning and profiling, especially for metals.
- For gentle cleaning and finishing, glass beads can yield a smooth surface.
- Walnut shells are a good alternative for delicate surfaces that require gentle abrasion without damage.
Bottom line, having a good understanding of your substrate, as well as your desired outcome, is key to selecting the most appropriate abrasive.
Learn more: Check out this handy guide to understanding the basics of abrasive media selection: https://short.pfonline.com/blastmedia
Pressure and distance
Blasting pressure and nozzle distance play an important role in successful surface preparation. Too much pressure will damage your substrate, while not enough pressure may not yield a clean surface. An optimum distance between your blasting nozzle and the surface is typically 12-18 inches. You’ll need to experiment and fine-tune these parameters and also adjust your pressure and distance based on your substrate material and the type of blasting media you are using.
You can never be too clean
Prior to media blasting, it’s helpful to make sure the surface is free from contaminants such as oil, grease, and loose dirt. Any residue can interfere with the blasting process and subsequently hinder coating adhesion. Thoroughly clean the surface with water or an appropriate solvent to remove dirt and residues. Use a suitable degreaser to remove oil and grease.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/PF/2024-PF/chooseppe-qrcode.png;maxWidth=385)
Take proper safety precautions
Media blasting involves high-pressure equipment and abrasive materials, which can be hazardous if proper safety measures are not adhered to.
- PPE: Always wear appropriate personal protective equipment (PPE), including eye protection, gloves and respirators, to protect against flying debris and dust.
- Ventilation: Ensure proper ventilation in the blasting area to avoid inhalation of dust and fumes.
- Training: Operators should be well trained in the use of blasting equipment and safety procedures. Following safety protocols not only protects the workers but also keeps the blasting process running smoothly.
Learn more: Check out these helpful tips for choosing PPE and safety equipment. https://short.pfonline.com/choosePPE
![](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/PF/2024-PF/maintaining-qrcode.png;maxWidth=385)
Preventive maintenance
A high-quality blast room is a significant investment and requires proper maintenance to ensure longevity. A proper maintenance schedule as prescribed by your equipment manufacturers should include regular inspection and replacement of filters, hoses and nozzles, PPE, and the blast room and surrounding areas.
Learn more: These steps will help maintain the efficiency and extend the life of your blasting facility. https://short.pfonline.com/maintaining
In the end, it′s all about the finish
Media blasting is a valuable option for surface preparation and can significantly improve the adhesion and durability of your coating. Choosing the right abrasive material, optimizing blasting parameters, following safety protocols and adhering to proper maintenance procedures for your equipment can set yourself up for great results for your final coating or finish.
Read MorePFAS in Surface Finishing: Where is it Going?
Regulation of PFAS chemicals continues to increase — here are some steps finishing operations can take to prepare.
