Mechanical Finishing Q&A: Blast Finishing for Brightness
What media is recommended for a brighter finish?
Q. We are blasting our aluminum parts in a blast cabinet after machining for a uniform finish. Our current process is blasting with 80-grit aluminum oxide to eliminate machine lines. What media is recommended for a brighter finish?
A. For brighter blast finishes, we recommend a No. 10 to 13 size glass bead or a 120-grit and finer ceramic media. Both media will produce a visually brighter and smoother roughness average (Ra) finish.
The aluminum oxide you are currently using is an angular abrasive that produces a duller visual matte finish and a courser Ra surface finish. It is a great media for the removal of scale, rust and paint. Aluminum oxide produces an excellent pre-paint and coating adhesion surface and will hide a large tool mark on machined parts.
The glass and ceramic beads are round abrasives that produce a brighter satin matte finish and a finer Ra surface finish. It can also remove light oxidation, rust, scale and paint, but at a much slower speed. Beads are generally used to produce a uniform, bright satin finish on machine and intricate parts.
If the beads do not hide all of the tool marks that the current aluminum oxide hides, try the following recommendations:
- Turn up the air pressure.
- Try a larger size bead.
- Blast first with the aluminum oxide and second with the beads.
- Mass-finish to smooth the lines first and then blast with the fine beads.
Originally published in the April 2016 issue.
Miles Chemical Anaheim Doubles Capacity with Second Building
Miles Chemical Anaheim is doubling its capacity with the purchase of a second facility adjacent to its existing one.
Modernizing Wastewater Treatment and Recovery
Source: Kontek Kontek’s “spigot to drain” Source Water and Wastewater Solutions offer integrated technologies to modernize your water & wastewater treatment and recovery.
