Rectifiers for the Plating Industry
More Environmental Cases are Going Criminal
Surface finishers and others operating in industries highly regulated by federal, state and local environmental protection agencies have seen an increase in the number of violations that have escalated from administrative notices of violations and fines, or even civil penalties, to criminal prosecutions
Surface finishers and others operating in industries highly regulated by federal, state and local environmental protection agencies have seen an increase in the number of violations that have escalated from administrative notices of violations and fines, or even civil penalties, to criminal prosecutions.
Criminal prosecutions can cost companies substantial financial penalties—sometimes millions of dollars in fines alone—plus probation oversight for several years, along with major capital improvements to bring facilities back into compliance. This is in addition to the possibility of being disqualified from bidding on government contracts. With the added potential for loss of liberty, the stakes are even higher for executives and employees.
Avoiding a criminal case is as simple as staying in compliance. Of course, as most of the regulated companies and their executives will tell you, staying in compliance is anything but simple.
Equipment breaks, parts wear out and inclement weather can all lead to noncompliance. Keeping the finishing lines running to enable a company to stay in business (and keeping employees off of the unemployment line) often leaves little, if any, room for lengthy downtime for repair.
For most companies, 100-percent compliance 100 percent of the time is much harder than it sounds. The good news is that the government understands this, and in appropriate cases it will exercise its discretion not to prosecute.
But the government understandably expects companies to anticipate and have plans in place to avoid non-compliance. There are several ways lawyers can help their clients in this regard.
The first method is to conduct an environmental audit to determine if the company is complying with the multitude of ever-changing regulations. Both state and federal governments have policies that basically provide for the reduction of penalties if the company voluntarily undertakes to conduct a compliance audit in good faith, promptly reports any violations discovered (with 21 days under the federal policy), and then expeditiously corrects those violations (generally within 60 days under federal policy) and prevents the recurrence of future violations.
What happens if the U.S. EPA decides to pursue a criminal enforcement action? First, a federal prosecutor will be asked to review the case and decide whether to seek an indictment. The U.S. Attorneys’ manual delineates the government’s Principles of Federal Prosecution of Business Organizations. One factor prosecutors consider when deciding whether to prosecute is whether the company has an effective compliance program—that is, has it anticipated and effectively planned to avoid (and to address) non-compliance from the outset.
Notably, of the 74 organizations sentenced in 2011, only four had an effective compliance program, according to the U.S. Sentencing Commission. In 2010, none of the organizations sentenced had one. While there are several other factors considered in charging a company with a crime, this data suggests a clear correlation between the decision to prosecute and the absence of an effective compliance program.
Prosecutors recognize that no program could ever prevent all criminal activity. They also recognize that one size does not fit all. Small companies are free to develop a flexible program that meets their unique operational needs. Larger companies, on the other hand, are expected to have more-formalized policies and protocols for implementing them, but they too remain free to tailor the program to suit their operations.
Regardless of the company’s size, however, the program cannot simply exist on paper. The program must be actively implemented daily as a part of doing business, and it must be designed to detect the particular types of misconduct most likely to occur in the company’s line of business.
In the environmental field, the EPA has long offered specialized guidance for each industry it regulates, which can serve as the starting point for developing a program for the company. Once the program is in place, management must be knowledgeable about the program, exercise reasonable oversight, and ensure that employees are trained and incentivized to comply.
Equally as important as the day-to-day implementation of the compliance program is how the company responds to actual or potential violations. Where there are actual violations, a company’s timely and voluntary disclosure of the violation, and its subsequent cooperation with prosecutors and law enforcement are factors in the charging decision.
In order to disclose useful information and meaningfully cooperate with the government, companies are well-served to conduct internal investigations. In many instances, a full-scale investigation by outside counsel is unnecessary. But for potentially serious matters, bringing in an experienced legal team will help the company quickly and thoroughly investigate the issue.
Not all internal investigations will result in a finding of misconduct, and corporate management should not view such investigations as wasted efforts. They almost always identify areas of concern and offer ways to improve operations. They also help establish evidence of the company’s ongoing commitment to a culture of compliance, which is important if a later investigation results in a disclosure to the government.
In some cases, a company may be indicted and ultimately convicted despite having an effective compliance program. All is not lost. Compliance programs still have value on the back end of the case. Since corporations cannot be sent to jail, punishment primarily comes in the form of onerous probation conditions, debarment from working on publicly-funded projects and a hefty fine.
And, if that is not enough incentive for a corporate client to implement a compliance program, the court can order the company to design a court-approved program and submit to regular oversight to ensure that it is properly implemented.
So in the end, foregoing a compliance program today may increase the likelihood of being criminally charged and result in a higher recommended fine, and the company could still be forced to adopt a compliance plan anyway. Implementing one is a smart investment for the client’s future.
Attorney Beth Gotthelf is a shareholder in Butzel Long’s Bloomfield Hills, Mich., office. She is co-chair of the firm’s Energy & Sustainability practice team and chair of its Aerospace & Defense industry team. Joseph Richotte is an associate in Butzel Long’s Detroit office. He practices in the areas of white-collar criminal defense, corporate investigations, media defense and professional discipline matters.
Reduced Ion Electroless Nickel
Luster-On Products
KCH Engineered Systems
Metal Pretreatment Technology
education
Caplugs Offers Webinar Series on Masking Design
Caplugs Connect platform offers education on product protection solutions.
Ask The Expert
Can You Afford to Not Use Custom Masking?
Are you weighing the costs of a custom masking solution vs. an off-the-shelf solution? Christy Schulthess of Custom Fabricating & Supplies discusses the overall savings that can be realized with custom masking.
masking
Masking Solutions for Diverse Applications
Global Mask of Barcelona, Spain showcases its solutions at Paint Expo 2024 in Germany.
masking
EPSI Relaunches Custom Masking Program
EPSI’s plotter cutting provides custom solutions for complicated masks and irregular shapes.
Parts Cleaning
Parts Cleaning
Sponsored
