Need a Different Mass Finishing Method
I have 4,000 parts/day of a flat stamping, much like a large flat washer. The problem is that the parts stick together and many of them only get finished on one side. What are your suggestions?
Q. I have 4,000 parts/day of a flat stamping, much like a large flat washer. The part is 3 x 0.150 inches. I use round vibratory finishing equipment with ceramic media. Finishing only takes 10 min. The problem is that the parts stick together and many of them only get finished on one side. I have tried adding small media such as glass beads, or sand, and it was not successful enough to eliminate inspecting and sorting, and the residue caused additional problems with my compound filtration and recirculation system. One company suggested a multi-pass vibratory machine. Parts could be fed in slowly enough that they would stay apart during the process, but the investment is very large for this equipment, and I don’t favor buying used equipment. What are your suggestions? H.G.
A. The pros and cons of a multi-pass machine can be argued at another time because it isn’t a good answer to your problem, given the small volume of parts. The flat washer people for years have used open-end tumblers, similar in appearance to a cement mixer. They tumble without media—a very low cost process. The downside is that the parts impinge each other and you get a dented surface. You told me you couldn’t accept that finish. Neither can some of the flat washer people. This has led some in that industry to change to centrifugal disc finishing. It can be done either part-on-part or with media. The action in these machines continuously slides the pieces apart, and I believe it will work for you. I recommend, as always, a production load demonstration.
Blasting Beads Made of Lead-Free Natron Glass
SwarcoBlast blasting media are made for use in a multitude of surface refinement applications.
Modernizing Wastewater Treatment and Recovery
Source: Kontek Kontek’s “spigot to drain” Source Water and Wastewater Solutions offer integrated technologies to modernize your water & wastewater treatment and recovery.
Blast Nozzle Features Enhanced Noise Reduction
Kennametal adds noise-reducing Blast Ninja to portfolio of abrasive blast nozzles.
