Paint Over Chrome
We currently use an aqueous cleaning system for our chrome plated parts before wet coat mask painting. The system is designed for exterior automotive adhesion specs. Can a modern vapor degreasing system provide the same adhesion?
Q1. We currently use an aqueous cleaning system for our chrome plated parts before wet coat mask painting. The system is designed for exterior automotive adhesion specs. Can a modern vapor degreasing system provide the same adhesion? R.M.
A1. If the only pretreatment given is an aqueous cleaning, vapor degreasing should provide the same adhesion characteristics. The paint doesn’t care how the part is cleaned—only that it is clean. You can prove this to yourself by asking the vapor degreaser vendor to clean some parts for you.
Q2. Thank you for your reply. I should have given you more detail on our aqueous cleaning steps. They are: mild detergent spray, cathodic electro- clean, rinse, chromic acid, rinse, DI rinse, oven dry-off. We have always tried to follow the rule of painting within 8 hr of plating to get the best adhesion, but due to product variations and quantities, most of the parts will sit 48 hr to a week after plating, before cleaning and coating.
Again, would a vapor degreasing system be a viable alternative? We are looking to do the same cleaning/activation in a smaller foot print. R. M.
A2. In a word, the answer is NO! I am glad you clarified your question by telling me the extent of the process. The only thing the vapor degreasing process will do is clean (by degreasing) the parts. It will not, I repeat, WILL NOT replace your present pretreatment process and will therefore probably not provide the same adhesion characteristics. Again, you can prove this to yourself by asking the vapor degrease vendor to clean some parts for you.
As this question shows, there is a lesson to be learned: When asking for outside help and advice, to get the right answer, it is important to ask the right question!
Replacing Open-Top Vapor Degreasing in Aerospace Manufacturing
Options and considerations for cleaning aerospace parts as regulations tighten on vapor degreasing solvents.
Solar Atmospheres of Western PA Receives Nadcap Accreditation
The company received the accreditation for it’s new, fully integrated Vacuum Oil Quench furnace, which provides a significantly cleaner and safer oil quenching process.
MicroCare Offers Alternatives to Discontinued Vapor Degreasing Fluids
MicroCare says it is equipped to handle customers affected by 3M's discontinuation of the Novec specialty fluids line with its own products.
