Powder Application Equipment
Source: Parker Iconics Parker Ionics will have on display its latest generation of powder application equipment, the Proficy Series. Sales engineers will be available to discuss how our Pulse Power Advanced Corona Charging Technology will save money while improving the coating finish. Keep valuable revenue in your pocket instead of your waste stream.
Parker Ionics will also discuss powder coating booth requirements and share valuable cost saving concepts.
A 3-D model of our Compact Configurable Shuttle System will be on display to help you understand the value of adding this to your production floor.
