Q&A: Removing Emulsified Oils from Cleaner
A reader asks: How can we remove the emulsified oils before painting shelving?
Q. We manufacture shelving for retail outlets and painted them on a spray paint line for years with no problems. We recently installed an electrocoating system where everything is new, including the cleaner stages, chemicals, type of paint and curing ovens. Now we are having problems with the presence of emulsified oils in our alkaline cleaner which messes up the finish on our products. How can we remove the emulsified oils? W.D.
A. Chemically, you can either change the stamping lubricant or change the cleaning solution chemicals. Physically, you can remove emulsified oils from the alkaline cleaner solution by ultrafiltration. Ultrafilters separate particles from solutions by using selective membranes. This often is done in the pretreatment stages of high-volume finishing lines. With ultrafiltration, the oil is essentially removed as concentrated emulsion from the cleaner solution, and the cleaned solution is then returned to the cleaner stage. This not only makes disposal of emulsified oil concentrate simpler, it also extends the life of the cleaner solution. Ultrafiltration can be done batch-wise or on a continuous basis, depending on the size of the unit and the rate of production.
To read more of Carl's answers, please click HERE
Specialty Oven’s Hot Benefits and Other Questions Answered
Learn about the advantages of gas catalytic infrared pre-gel ovens in this article, including how they are energy efficient and can save users time and money when integrated into their existing systems.
Oven Door Technology Improves Energy Efficiency
The RollSeal Door brings a compact, energy efficient and safe design to batch and conveyor style thermal processing units.
Powder Coating Overcomes Post Forming
