Solution Curve
Question: I would like a copy of a “solution curve” for zinc.
I would like a copy of a “solution curve” for zinc. I think that is what you call the curve, with ppm on one axis and pH on the other. Can you point me in a direction? No luck on the web. W.H.
Try turning your web search engine to www.google.com and type “zinc hydroxide precipitation” in the search field. I did so and obtained a number of good hits, one being a paper from mtex.org (Maryland Technology Extension Service) on wastewater treatment that does contains the zinc curve, as well as other heavy metals. All of the “solution curves” that I have seen show the minimum dissolved zinc concentration as a metal hydroxide to be around a pH of 8.5, however, since zinc is typically precipitated with other metals, these metals will also impact the best pH for zinc hydroxide precipitation. Hope this helps.
Industrial Finishing Products
PMTS 2025 Register Now!
find masking products online
Metal Pretreatment Technology
