Sulfamate Nickel and Aluminum
We have a sulfamate nickel plating bath that has more than 1,400 ppm of aluminum present. Will this affect the quality of the sulfamate nickel deposit? How can we remove the aluminum from the bath?
Q. We have a sulfamate nickel plating bath that has more than 1,400 ppm of aluminum present. Will this affect the quality of the sulfamate nickel deposit? How can we remove the aluminum from the bath? S.N.
A. I remember reading a number of years ago that aluminum in a nickel sulfamate plating bath affects the upper limiting current density. Unfortunately, I am unable to find the original article with the information.
From my days as a practicing chemist I can tell you the aluminum will precipitate out as aluminum hydroxide once the pH of the bath is higher than 3.5. If aluminum oxide does precipitate out, you will notice roughness in your deposit. Removal of the aluminum can be accomplished by raising the pH and filtering the plating solution. This is not a “slam dunk” process since the aluminum hydroxide that forms becomes colloidal and rather messy to filter. The aluminum hydroxide is gel like in structure and tends to plug filters with a reckless abandon. Sometimes a filter aid can be used to reduce or alleviate this problem.
The most obvious thing here is for you to figure out where the aluminum is coming from. In my experience, I have never seen or heard of a situation prior to yours in which aluminum was present in a nickel sulfamate bath in the concentrations you mention.
Trivalent Chrome Overview
